How to correct SQL expression for Search Cursor in Arcpy
5067
08-14-2015 08:11 PM
fumaniwada1
I need to create a search cursor to print out the values in an attribute table for a school shapefile. I need to print out all the values that correspond to HIGH SCHOOL in the field FACILITY for the School shapefile. For some reason the search cursor won't work when I try to apply the sql expression but works without it. I don't want to print out all the values in that field just specific ones. Is there something wrong with my sql statement?
#import arcpy module
import arcpy
from arcpy import env
# I am setting the work path
env = 'S:\\376\\Summer15-2\\ahutche1\\lab07_data\\SectionB\\'
#I will set the variable for the schools shapefile
schools = 'Schools'
#create search cursor to loop thru schools. use where clause to return schools
#that are high schools. Use loops
#print out all the highschool names
#print total no. of high school records
sr = arcpy.SpatialReference(4326)
#I will create a search cursor for the schools shapefile
field = "FACILITY"
exp1 = '"FACILITY" = "HIGH SCHOOL"'
cursor = arcpy.SearchCursor(env+schools+'.shp',exp1)
for row in cursor:
    print(row.getValue(field))
XanderBakker
Esri Esteemed Contributor
There are a few issues:
  • First of all, please use the instructions found here: Posting Code blocks in the new GeoNet  for insert code into a thread
  • The code does not work since the where clause is not valid. The delimiters of a field depend on the type of data used (shapefile, personal- file or enterprise geodatabase). Use the AddFieldDelimiters to structure the where clause.
  • If the would have worked, the statement "print(row.getValue(field))" would have printed the value HIGH SCHOOL for each high school and not the name
  • In the code below on line 12 a list of all the HIGH SCHOOL names is made and on line 17 the length of that list is printed.
def main():
    import arcpy
    fc = r"S:\376\Summer15-2\ahutche1\lab07_data\SectionB\Schools.shp"
    fld_fac = "FACILITY"
    fld_name = "FieldNameWithHighSchoolNames" # specify the name of the field
    # create a valid where clause
    sql = "{0} = 'HIGH SCHOOL'".format(arcpy.AddFieldDelimiters(fld))
    # print out all the highschool names
    lst = [r[1] for r in arcpy.da.SearchCursor(fc, (fld_fac, fld_name), sql)]
    for name in lst:
        print name
    # print total no. of high school records
    print "There are {0} High Schools".format(len(lst))
if __name__ == '__main__':
    main()
Code has not been tested and should be used with ArcGIS 10.1 SP1 or higher ...
BlakeTerhune
MVP Frequent Contributor
On line 9, you have an udefined variable fld in AddFieldDelimiters(). It also gives
TypeError: AddFieldDelimiters() takes exactly 2 arguments (1 given)
It needs a data source, then field name.
AddFieldDelimiters—Help | ArcGIS for Desktop
XanderBakker
Good catch, thanks!
Corrected code below (still not tested):
def main():
    import arcpy, os
    fc_ws, fc_name = os.path.split(fc)
    sql = "{0} = 'HIGH SCHOOL'".format(arcpy.AddFieldDelimiters(fc_ws, fld_fac))
    for name in lst:
        print name
    main()
...edit: Blake T detected another error in my code: the fld variable on line 10 is not set and should be replaced by fld_fac which holds the name of the FACILITY field...
WesMiller
When doing SQL expressions for python code i usually start by creating the query in select by attribute and then copy it to the code this usually ensures i have the correct syntax
