How to copy new rows from a shapefile to a feature class
4163
6
01-24-2021 05:16 PM
MaryamPanji
Hi, I am trying to add new features from a shapefile to a feature class sitting in database in sql server. Both have common fields but name of a few fields are different.
My question is that how can I automate this process using  a python script.
I am new with Python and I've created this one but I am getting this error:
Runtime error
File "<string>", line 16, in <module>
File "<string>", line 4, in getPrimaryFieldValues
TypeError: 'field_names' must be string or non empty sequence of strings.
My script looks like this:
ID is the field that the script should check it if the values don't exist then insert the rows.
import arcpy
def getPrimaryFieldValues(fcfield😞
    values = []
    with arcpy.da.SearchCursor(fc, [field]) as cursor:
        for row in cursor:
            values.append(row[0])
    return values
def getSelectCursor(fcwhereClause😞
    return arcpy.da.SearchCursor(fc, ["*"], whereClause)
def diff(ab😞
    b = set(b)
    return [aa for aa in a if aa not in b]
source = r"original"
destination = r"test"
fieldName =["ID"]
sourceValues = getPrimaryFieldValues(source, fieldName)
destinationValues = getPrimaryFieldValues(destination, fieldName)
add = diff(sourceValues,destinationValues)
with arcpy.da.InsertCursor(destination, ["*"]) as insertCursor:
    for a in add:
        insertRows = getSelectCursor(source, fieldName + " = " + str(a))
        for r in insertRows:
            insertCursor.insertRow(r)
Tags (1)
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - GeoNet, The Esri Community
will get rid of all you sad faces in your code and make it more readable 😉
On a quick look, I am not sure if you set up field mapping
Mapping input fields to output fields—ArcGIS Pro | Documentation
... sort of retired...
MaryamPanji
import arcpy
def getPrimaryFieldValues(fc, field):
	values = []
		for row in cursor:
	return values
def getSelectCursor(fc, whereClause):
	return arcpy.da.SearchCursor(fc, fieldName, whereClause)
def diff(a, b):
	b = set(b)
source = "Original"
destination = "Test"
fieldName = ['OBJECTID','F_1','F_2','Description','Class','CatShortDesc','CatLongDesc','Condition','GeoUnit','Easting','Northing','created_user','created_date','last_edited_date','SHAPE@XY','Comments','Class_Code']
additions = diff(sourceValues,destinationValues)
with arcpy.da.InsertCursor(destination, fieldName) as insertCursor:
	for a in additions:
		insertRows = getSelectCursor(source, fieldName)
MaryamPanji
Thanks Dan, I fixed the script.
by Anonymous User
Not applicable
I am not sure where you are getting your source and destination field list, but here is a function that I use when we need to do field mapping between two featureclasses. Append might be a better option over cursors, but I don't know the specifics of what you want moved.  If you must use cursors, this still might help with getting an idea how to get a list of field names to iterate over.
def fieldMapping(destfc=None, sourcefc=None, keepfields=None):
        Function to assist in making joins by mapping all the fields in the destination fc and
        including a list of fields that is wanted within the source dataset..
        try:
            trglist = [i.name for i in arcpy.ListFields(destfc)]
            # List of fields to keep during Join operation
            fldMap = arcpy.FieldMappings()
            # Creating field maps for the two files
            fldMap.addTable(destfc)
            fldMap.addTable(sourcefc)
            keepfields.extend(trglist)
            # Removing unwanted fields
            for field in fldMap.fields:
                if field.name not in keepfields:
                    fldMap.removeFieldMap(fldMap.findFieldMapIndex(field.name))
            return fldMap
        # Error handling...
        except RuntimeError as e:
            raise Exception("{} failed.\n{}".format(sys._getframe().f_code.co_name, e.message))
Use the returned field map:
# Process: Create the field map for the join
keepfields = ['address', 'zip']
zcodesMap = fieldMapping('destination fc', 'source fc', keepfields)
If there are fields that need to be manually mapped, you can so so like:
# using the field map created by the function, add the fields that have different names
zcodesMap.addInputField(destfc, 'fieldname in sql')
zcodesMap.addInputField(sourcefc, 'old field name')
usefldmap_name = zcodesMap.outputField
usefldmap_name.name = 'fieldname in sql'
zcodesMap.outputField = usefldmap_name
Then you can use the field map in append, join, etc to move your data.
arcpy.Append_management(srcAdd, address, "NO_TEST", zcodesMap)
MaryamPanji
Thanks @Anonymous User , I've used cursors cause I wanted to find non-existing rows and then insert them into the feature class. I can change the field names and don't need to do field mapping. There is one field which is unique and I can compare the feature class with the shapefile. if I want to summarise what I want to do is that:
check the shape file based on a field (GeoUnit) and if the values don't exist in GeoUnit of the feature class then insert the rows in feature class.
by Anonymous User
Not applicable
Thanks for pasting the script.
In your updated code, the whereclause is missing.  Using the whereclause in the original pasting, it looks like you were trying to select the fieldname by the sql statement, which will fail because the whereclause is for filtering/selecting the data.
If you are only comparing the one (GeoUnit) field, you only need to grab that value in your lists.  I refractored your code a little to:
import arcpy
def diff(a, b):
    # Filter out existing values
if __name__ == "__main__":
    source = "Original"
    fieldNameList = ['OBJECTID', 'F_1', 'F_2', 'Description', 'Class', 'CatShortDesc', 'CatLongDesc', 'Condition', 'GeoUnit', 'Easting', 'Northing', 'created_user', 'created_date', 'last_edited_date', 'SHAPE@XY', 'Comments', 'Class_Code']
    additions = diff([x[0] for x in arcpy.da.SearchCursor(source, 'GeoUnit')],
                     [x[0] for x in arcpy.da.SearchCursor(destination, 'GeoUnit')])
    # iterate over list of GeoUnit values that are not in the featureclass
    for a in additions:
        # select the values in the shapefile based on the whereclause
        whereclause = f"""GeoUnit = '{a}'"""
        with arcpy.da.SearchCursor(source, fieldNameList, whereclause) as cur:
            for row in cur:
                # Insert the values from the shapefile cursor into the fc.
                # The order of the fields in the fieldlist matters here so match their index to the index of the destination FC that you are using.
                with arcpy.da.InsertCursor(destination, fieldNameList) as insertCursor:
                    insertCursor.insertRow(row[0])
Hope this helps, and that I understood your intention.  You could do this with dictionaries as well, so you don't have to iterate over the shapefile a second time but this might work just as well without getting too complex.
