How to convert a Google Spreadsheet to a .csv file with Python
6061
7
11-13-2013 03:32 PM
JosephGrove
I am working with a google spreadsheet that shows active big foot sightings data.  What I am trying to do is convert the google spreadsheet to a .csv file so that I can then use geoprocessing tools placed in GIS Model Builder to take the .csv file and turn it into a table, and then a point shapefile showing the xy coordinates.  That part is easy.  It's just the first step that has me.  I am receiving a syntax error when I try to run the python script.  Here is what I have:
import csv
import gspread
g = gspread.login('skiesgoinggreen@gmail.com', '???')
docid = "0AgNp9UJ4CX93dHl3RW9GRXJDS3kxaXRJMGNqWmhQWVE"
spreadsheet = g.open_by_key(docid)
for i, worksheet in enumerate(spreadsheet.worksheets()):
    filename = docid + '-worksheet' + str(i) + '.csv'
    with open(filename, 'wb') as f:
        writer = csv.writer(f)
        writer.writerows(worksheet.get_all_values())
Thank you in advance for your help and suggestions.
JasonScheirer
What version of ArcGIS are you on?
Instead of
    with open(filename, 'wb') as f:         writer = csv.writer(f)         writer.writerows(worksheet.get_all_values())
try
    writer = csv.writer(open(filename, 'wb'))     writer.writerows(worksheet.get_all_values())
JasonScheirer
Please use the [#] button in the formatting toolbar on your code when you post. I can't see where your indentation is. Does it look like this?
import csv
import gspread
JosephGrove
What you changed it to is correct on what the script is supposed to look like.  I apologize about the formatting mistake.
JasonScheirer
Once I indented it like that I no longer got a syntax error, so problem solved?
JosephGrove
Thank you Mr. Scheirer for sticking with me and continuing to provide advice and guidance.  I ran the code using Python Win and then Python Idle 2.7 and am still receiving a syntax error on line 11 on the word open.  With me being very new to Python I am not sure if I have to add anything extra to this script like specific file names or pathways as I am currently just running the code as seen below.
Thank you again for your patience and help.
import csv
import gspread
g=gspread.login('skiesgoinggreen@gmail.com', 'XXXXXXXXXXXX')
JasonScheirer
Instead of
try
JosephGrove
Mr. Scheirer,
Thank you so much for the script modification suggestion.  I am going to try to run the updated python script today.  Currently I am using the trial version of arcgis 10.2.
Thank you again for your help.
JosephGrove
This part of the script is working!  Thank you Mr. Scheirer!
