how to connect to SDE version using stand alone python script
5542
11-28-2014 04:18 AM
TarunPunetha1
How to connect a argis, sde version through stand alone python script. SDE.Mapping is child version of SDE.Default and I want to make child version of SDE.Mapping . I am using direct sde services, sde:oracle11g:dbname
I need to know command of python to connect to a sde version.
JakeSkinner
Esri Esteemed Contributor
Hi Tarun,
You can do this using the Create Database Connection tool.  There is an optional parameter, version, where you can specify the database version.  Ex:
arcpy.CreateDatabaseConnection_management("Database Connections", "ORCL", "ORACLE", "SDESERVER", "DATABASE_AUTH", "vector", "vector", "SAVE_USERNAME", "#", "#", "TRANSACTIONAL", "VECTOR.Child1")
TarunPunetha1
Thanks Jake, it worked
TarunPunetha1
Jake, do you know
How  to start, stop and save edits in python script for arcmap version 10.0.
arcpy.da.editing is working for arcmap 10.1 version onwards
RemiAmbattakathutt
Jake,
I am having a similar issue. I am trying to connect to a version other than DEFAULT by providing version parameter. But it is always connecting to DEFAULT version. Could you please provide any input on this? Here is the code i used
arcpy.CreateDatabaseConnection_management(out_folder_path="Database Connections",
                                          out_name="creaconn5.sde",
                                           database_platform="ORACLE",
                                           instance="srv1/testgis",
                                          account_authentication="DATABASE_AUTH",
                                          username="sde",
                                          password="xxxx",
                                          save_user_pass="SAVE_USERNAME",
                                          version_type="TRANSACTIONAL",
                                          version="TEST.VERSION1")
In the immediate window right pane it shows as
Executing: CreateDatabaseConnection "Database Connections" creaconn5.sde ORACLE srv1/testgis DATABASE_AUTH sde ***** SAVE_USERNAME # SDE TRANSACTIONAL # #
You can observe that, even though I specified version parameter, it took it as blank (#)
Could you help in identifying what went wrong?
