How to communicate two lists
5830
7
04-23-2015 04:03 PM
PierreWeisse
Hello,
I'm having trouble with lists.
I work on two different workspaces
The first is a file geodatabase (a)
The second is an SDE geodatabase (b)
The aim is to remove the contents of feature classes contained in a list (b)
So far so good
Then copy the new records (a) in the entity classes of (b)
To delete the records I use arcpy.DeleteFeatures_management () function
To complete the feature classes with the new content I use the function
arcpy.CopyFeatures_management ()
Thank you for your help
DanPatterson_Retired
so...how is it going?  Have you done this manually? Are you trying to produce a script from it?  Examine the Results Window to see the script syntax if so.  It will give you a starting point as to how to put this together.  Alternately, construct a model from modelbuilder which can be used itself and/or converted to a script.
PierreWeisse
Thank you very much for the quick reply.
Here is my script:
import arcpy, os
from arcpy import env
env.workspace ="M:\UTILISATEURS\Pierre\connexion SDE\srv-arcsde.recif.nc@sde_ore_adm.sde\SDE_ORE_ADM.TEST"
lst_destination = arcpy.ListFeatureClasses()
for fc in lst_destination:
    arcpy.DeleteFeatures_management(fc)
    print fc + " is delete"
So far, so good. This is the next step that I have a problem.
I can not seem to communicate this list with another list, to come to copy the new entities in the feature classes that have been deleted.
​same procedure using Feature Class to Feature Class syntax as shown in the help topic.
I would, however, suggest that you copy the features from the source location first, prior to deleting them.  If the files are outside of a geodatabase, you can use pure python operating functions...but that is a different story.
PierreWeisse
I can not use the tool "Feature Class To Feature Class (Conversion)"
That's why I use the tool arcpy.DeleteFeatures_management (). I work in an organization with many users who use data during updates.
This tool allows the updates even when users are connected to the base.
Process:
To clear the table for these records
To fill the table with records last days
Thank you
JoshuaBixby
MVP Esteemed Contributor
Are you working with versioned data?  The code snippet you provide will delete all of the features in the feature classes, so it appears you are completely purging the table and repopulating it from scratch.  If you are working with versioned data, this will make your add & delete tables grow substantially.  Do you really need to replace all the records or are you trying to synchronize subsets of records between the two data sources?  Deleting all the records in an SDE table when users are consuming data from the table seems like it would lead to some strange experiences for users.
PierreWeisse
Hello Joshua and Dan,
These data are not versioned. These are data from one of our partners. They take care to versioning. Our organization recovers data via their FTP.
The data that we update, have a comparable table structure of an update to another. There may be new entities or additional information in the fields.
I use the functions:
Because the data can be used by other users when I wish performed the update. These same users are warned in advance that an update will take place. They are not surprised. A document is even sent them for their explained what those updates.
Thank you both
JoshuaBixby
OK, got it.  You are caught up in Esri semantics.  The Copy Features tool won't work for you because it copies "features from the input feature class or layer to a new feature class."  Check out the Append tool.  Although it will work with multiple input datasets, it works just fine with one input dataset.
