How to check the ListLayers(Map) is Empty or not
2035
03-07-2011 02:23 PM
BruceGreen
Hi guys
I am looking for a method to find out if the ListLayers id empty or not using arcpy.mapping
I appreciate if you ca give me an idea bout this
Thanks
NiklasNorrthon
layerlist = arcpy.mapping.ListLayers(...)
if layerlist:
     do_something()
else:
     handle_empty_layer_list()
BruceGreen
Thanks Niklas
I will check it and reply you the result
RichardDaniels
MVP Regular Contributor
I know this is an old thread, but a working snip was never posted, so here you go!
TurnOffLayer.py
_________________
import arcpy
fileName=arcpy.GetParameterAsText(0)
mxd = arcpy.mapping.MapDocument("CURRENT")
lyr=arcpy.mapping.ListLayers(mxd, fileName)
if lyr:
    if lyr[0].visible==True:
         lyr[0].visible=False
         arcpy.RefreshActiveView()
sys.argv[2]=True
arcpy.SetParameter(1,"True")
