How to Batch Geocode with ArcGIS Online using Python?
6475
04-21-2015 02:27 PM
TimothyJohnston
I am trying to figure out how to batch geocode a table of addresses using the ArcGIS Online World Geocoder using Python.  I have an enterprise account. I don't get any errors when I run my script. The result is a point FeatureClass with all the input records but they all have a null shape so nothing displays on a map.  Here is my python code:
import arcpy
from arcpy import env
env.workspace = "C:/TestData/Geocode.gdb"
try:
  arcpy.SignInToPortal_server("<my arcgis online enterprise userid>", "<my password>", "http://www.arcgis.com/")
  in_table = r"MYTABLE"
  # ArcGIS Online Locator found in ArcCatalog
  locator = r"Ready-To-Use Services/Geocoding/World.GeocodeServer"
  out_table = r"GEOCODE_RESULTS"
  fields = r"Address Address;City City;Region State;Postal Zip"
  arcpy.GeocodeAddresses_geocoding(in_table, locator, fields, out_table, "STATIC")
except Exception as e:
  print e.message
  arcpy.AddError(e.message)
TimothyJohnston
TimothyJohnston
I discovered the answer on github.  Hopefully this will help someone else with the same question.
https://github.com/deelesh/batch-geocoding-python
http://proceedings.esri.com/library/userconf/devsummit13/papers/devsummit-183.pdf
Anish_Adhikari
I tried the github code and I am consistently getting errors with the last function which does the actual geocoding. I have tested and retested and it creates output geodatabase and Arcgis online connection fine(see screenshot). The only thing I have added on the code part is adding my arcgis online credentials.
This is the error I am getting
>>> Traceback (most recent call last):
File "C:\Python27\ArcGIS10.4\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
exec codeObject in __main__.__dict__
File "C:\GIS_Data\geocode\BatchGeocoding.py", line 56, in <module>
output_feature_class)
File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\geocoding.py", line 220, in GeocodeAddresses
raise e
ExecuteError: ERROR 000010: Geocode addresses failed.
Failed to execute (GeocodeAddresses).
Any ideas?
BruceHarold
Esri Frequent Contributor
You can try this tool in ArcGIS Pro, there is also the arcgis Python API you can use in a Jupyter notebook, for example this example.
Anish_Adhikari
Thank You Bruce,
I ended up creating a model in Arcmap and exported it as a Python script and it is working so far.
