I have two Polyline Features, with a cross-road point.
When i run an Intersect, it creates a segment wich is multi-part, as you see in the pictures attached.
Is there a way to avoid this from happening?
Thank You.
Since this is in Python, I assume you are doing this by code Polyline—Help | ArcGIS for Desktop using intersect in that class. You could follow this by a union. If the features are coming from two different feature classes, then the dissolve should work on that feature
