How to avoid a multipart-line of being produced by an intersect
2296
03-11-2016 12:21 PM
TércyoStorck1
I have two Polyline Features, with a cross-road point.
When i run an Intersect, it creates a segment wich is multi-part, as you see in the pictures attached.
Is there a way to avoid this from happening?
Thank You.
DanPatterson_Retired
Since this is in Python, I assume you are doing this by code Polyline—Help | ArcGIS for Desktop  using intersect in that class.  You could follow this by a union.  If the features are coming from two different feature classes, then the dissolve should work on that feature
