How to add table columns value in the Text element, Map Layout View through ArcPy
1220
11-20-2017 05:56 AM
raviprakash
Hi Everyone,
               Could you please help me to add column value of table(Non-spatial) data into the text element of the map document and print a pdf file.
Table data will be like below screenshot.
Map Layout view will be like below screenshot:
Thank you for help
DanPatterson_Retired
Ravi
Your question... It currently sounds like you want someone to develop it for you.
It might be best to show what you have done and what you have tried.
This tends to solicit suggestions to assist in the process.
Blank requests to do something tend to languish for a while.
Anything that you have done along the path to solution will save people time and they will get a better sense of exactly what you need and where you have been in the process.
