How to add a button in geoprocessing tool?
1813
10-14-2024 01:36 PM
BittersDaniel
I was wondering if there is a way to add a button to a geoprocessing tool to validate and have a pop-up message before the user runs the tool.
For example, the Add Join tool has a button like this.  I couldn't find a way to add a button though and am wondering if I am missing something.  Thanks!
DanPatterson
MVP Esteemed Contributor
you can validate a tool
Customizing script tool behavior—ArcGIS Pro | Documentation
you can get a checkbox but not a button if have optional parameters
... sort of retired...
HaydenWelch
MVP Regular Contributor
Here's a simple example tool that should work using @DanPatterson 's checkbox button idea. I use checkbox buttons this way all the time:
import arcpy
class ValidateButtonExample:
    """Generates frames for a given layout"""
    def __init__(self) -> None:
        self.category = "Example"
        self.label = "Button Parameter"
        self.description = "A Button Parameter Example"
        return
    def getParameterInfo(self):
        validate_button = arcpy.Parameter(
            name="validate_button",
            displayName="Validate",
            direction="Input",
            datatype="GPBoolean",
            parameterType="Required",
        validate_button.value = False
        return [validate_button]
    def updateParameters(self, parameters:list[arcpy.Parameter], messages:list) -> None:
        """Modify the values and properties of parameters before internal validation is performed."""
        params = named_params(parameters)
        if params.validate_button.value:
            self.validate(parameters, messages)
            params.validate_button.value = False
        return
    def validate(self, parameters:list[arcpy.Parameter], messages:list) -> None:
        """This is run when someone clicks the validate checkbox"""
        parameters = named_params(parameters)
        # Implement your validation logic here
        return
    def execute(self, parameters:list[arcpy.Parameter], messages:list) -> None:
        """This is run when someone clicks the Run button"""
        # Implement your tool logic here
        return
def named_params(parameters:list[arcpy.Parameter]) -> object:
    """ Return an object with named parameters """
    params = object()
    for param in parameters:
        setattr(params, param.name, param)
    return params
BittersDaniel
Thanks for that example, I might try to implement something like that.
One scenario I am concerned about is if a user starts checking and unchecking the box within seconds, which would probably interrupt any geoprocessing functions that need to happen in the validation and could confuse the tool.
