How do you loop through a list of files, getting the filenames, and then adding the names to a standalone table?
10565
23
09-16-2019 05:47 AM
RPGIS
by MVP Regular Contributor
i am relatively new to python but I am trying to work on a script that works in conjunction with modelbuilder and so far things were working up to a point. The issue that I am having is I am trying to loop through a list of files, get the filenames, and update a table with the names from the files. Here is the script that I have currently:
import arcpy
import os
#Set Parameters
inFiles = arcpy.GetParameterAsText(0)
inTable = arcpy.GetParameterAsText(1)
inField = arcpy.GetParameterAsText(2)
outTable = arcpy.SetParameterAsText(3)
#Iterate through files in folder, insert rows based on file names, and make table view layer
with arcpy.da.InsertCursor(inTable, inField) as cursor:
    #List Files
    flist = arcpy.List(inFiles)
    for f in flist:
        #Make table view
        arcpy.MakeTableView_management(inTable)
        #Get filename(s)
        f = os.path.basename(flist).rstrip(os.path.splitext(flist)[1])
        #Insert values and rows in table
        cursor.insertRow([f])
del cursor
#Add Message
arcpy.AddMessage("This row {0} was added.".format(f))
Any help on this would be greatly appreciated.
JamesCrandall
That's what it should be doing as it's simply using whatever you add to the "inFiles" list.  In my example it would only add the 3 items.  If you had populated the list with 20 file references then it would have added 20 rows to the table.  Not sure if that answers your question.
LaurenceLanglois1
This might be an obvious trick, it is a manual step though.
In Windows Explorer.
Select all files in you directory.
Hold Shift and 'Right Click'
'Copy as Path'
Paste into excel or notepad.
Save record
Point to your new file...
RPGIS
Ok. Because for some reason I am able to parse the path using modelbuilder and it returns the correct record. The only issue I have with using the script in modelbuilder is that I receive an error message stating the table either does't exists or it simply doesn't open. I have a slightly more dumbed down version of the model that works but I my end goal is to use the script in process with the model which would make this process more seamless. Otherwise the model and script combination that is working currently, works as two separate model tools. So I am simply trying to figure out the best approach to make two processes work as one.
PavanYadav
Not sure if arcpy.da.Walk will fix your issue but you might want to use if you're interested in listing datasets in subdirectories as well.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
RPGIS
Thanks Pavan,
I checked with one of my coworkers on this and he walked me through a process that you mentioned. Here is the script that he gave me as well as my own additions(mostly his).
import os
path = r"C:\Folder\FolderName"
files = []
for r, d, f in os.walk(path):
    for file in f:
        if '.mdb' in file:
            files.append(file)
for f in files:
    ##print(f)
    strip = os.path.basename(file).rstrip(os.path.splitext(file)[1])
    print strip‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This solution was what I was actually trying to get to but, with my knowledge of python being so limited, I don't have a firm grasp on it. I meet with a friend every now and then to study python, but there is more to python than I can feasibly grasp.
-Robert
PavanYadav
Hi Robert , I notice you are using os.walk not arcpy.da.Walk. That's okay if it serves your purpose  but os.walk is file based and does not recognize database contents such as geodatabase feature classes, tables, or rasters. I thought I should point it out because in the future you might find it useful.
Pavan Yadav
AI for Imagery
RPGIS
Thanks Pavan. I didn't write that portion of the script, somebody else did and so I used it to test the script and it worked. I know that with the cursors you have to use .da. I didn't know that os.walk also needed the .da as well. I will be sure to remember that.
PavanYadav
Robert, they are two different but similar functions. See the Discussion section at this help page: Walk—Data Access module | ArcGIS Desktop
in most cases, os.walk works. So, please don't worry about changing it.
Pavan Yadav
AI for Imagery
RPGIS
Thanks Pavan,
I won't worry about making changes. I'm still trying to get a better understanding of how the scripting in python affects the behavior of the overall script,  and how this can change the overall outcome of the desired result. The other thing that I'm still trying to grasp, that I simply don't fully understand at this point,  is the direction. I know what I would like for my end result to be at times, but getting there via scripting is more challenging. I'm really familiar with modelbuilder and I can create most tools from simple models. I realized that the end result that I want to get to is sometimes missing with the given esri tools. I realized that I could fill in for those missing pieces by creating script tools to fill in those gaps, or simplify long drawn out models by simplifying them to scripts. I arrived to the conclusion that I might need to practice more and get familiar with the basics. It's just that there's more to python than I originally thought, and there's other components that I was unaware of. So this is going to take time, but I would like to eventually get to the point that I can understand these things well enough that I won't get lost in the process. Any advice on this would be heavily appreciated.
- Robert
GailMorrison
This might be easier to do in Excel:  I can't give you all the steps as they have govt. pathnames within the screen scratches.  When you click on From Folder, a gui opens to allow you to Browse to a folder path, then click OK.  Once a directory list is created, you can move the columns around. Using the Extension down'arrow, you can sort for just *gdb, *shp, etc.  Last, Close & Load To ... (an excel worksheet).  It's very fast & easy to use.
www.youtube.com/watch?v=GO-Q8j2lW2s
Get a List of File Names from Folders & Sub-folders in Excel (using Power Query) - YouTube
Last step:
