How do I update the location of a feature in an AGOL hosted Feature Layer?
1128
06-11-2018 08:28 AM
JohnSolly4
I am trying to randomly move a feature in an AGOL layer. The layer has a geometry property that is in web mercator and lat/long (WGS84) fields in the attribute table. Anyone know how I can update the location of the feature AND keep the lat/long fields in sync?
This is what I have tried:
latitude = feature.get_value("lat")
longitude = feature.get_value("long")
geometry = feature.get_value("geometry")
print (f"The latitude is {latitude}")
print (f"The longitude is {longitude}")
print (f"The geometry is {geometry}")
feature.set_value("lat", feature.get_value("lat")+random.uniform(0,1))
feature.set_value("long", feature.get_value("long")+random.uniform(0,1))
geometry_dict = feature.get_value("geometry")
geometry_dict['x'] += random.uniform(0,10)
geometry_dict['y'] += random.uniform(0,10)
feature.set_value("geometry", geometry_dict)
The code above results in the following output:
The latitude is 43.8849
The longitude is -100.3152
The geometry is {'x': -11167036.982825391, 'y': 5447647.436134641}
The latitude is 44.38470494318065
The longitude is -99.40659382285271
The geometry is {'x': -11167031.21161315, 'y': 5447647.819034746}
As you can see, changing the geometry does NOT change the Lat/Long properties. Do I have to do a conversion and update these fields separately? What would be the most efficient way to do this?
RandyBurton
One way is by using projectAs.
# WGS 1984 : (4326) Lat/Lon
# WGS 1984 Web Mercator (auxiliary sphere) : (102100) or (3857)
ptGeometry = arcpy.PointGeometry(arcpy.Point(x,y),arcpy.SpatialReference(4326)).projectAs(arcpy.SpatialReference(3857))
print ptGeometry.firstPoint.X, ptGeometry.firstPoint.
