How do I loop this to go through the every feature in the layer.
3187
05-21-2018 09:32 AM
JAJoffre
I'm trying to loop this to go through the every feature in a layer. New to python and learning on the go here. This is the first time writing something so if see anything else let me know.
Import arcpy
... # Local variables:
... GasUtilNode_Segment = "GasUtilNode_Segment"
... GasUtilNode_Segment__3_ = GasUtilNode_Segment
... GasUtilNode_gControlFitting = "GasUtilNode_gControlFitting"
... GasUtilNode_gControlFitting_ = "\\\\zpstg07.mcip.usmc.mil\\roaming_profile\\home$\\geofi\\JJoffre\\Documents\\ArcGIS\\Default.gdb\\GasUtilNode_gControlFitting_"
... # Process: Select
... arcpy.Select_analysis ("GasUtilNode_gControlFitting", r'P:\YU_Restricted\Yuma_Admin\Projects\FY18\WO18_100_199\18-190_Gas_Utilities_Update_(Plicka_Joffre)\Gas_Utilites.gdb\UTILITIES_GAS\Fitting2', "OBJECTID = 1")
... # Process: Make Feature Layer
... arcpy.MakeFeatureLayer_management( "Fitting2",r'P:\YU_Restricted\Yuma_Admin\Projects\FY18\WO18_100_199\18-190_Gas_Utilities_Update_(Plicka_Joffre)\Gas_Utilites.gdb\UTILITIES_GAS\Fitting2Layer', '#', '#', "OBJECTID OBJECTID VISIBLE NONE;gasUtilNodeIDPK gasUtilNodeIDPK VISIBLE NONE;gasNodeType gasNodeType VISIBLE NONE;mediaID mediaID VISIBLE NONE;operationalStatus operationalStatus VISIBLE NONE;realPropertyNetworkIdentifier realPropertyNetworkIdentifier VISIBLE NONE;realPropertySiteUniqueID realPropertySiteUniqueID VISIBLE NONE;realPropertyUniqueIdentifier realPropertyUniqueIdentifier VISIBLE NONE;sdsFeatureDescription sdsFeatureDescription VISIBLE NONE;sdsFeatureName sdsFeatureName VISIBLE NONE;sdsMetadataID sdsMetadataID VISIBLE NONE;facilityConditionIndex facilityConditionIndex VISIBLE NONE;facilityIDFK facilityIDFK VISIBLE NONE;facilityNumber facilityNumber VISIBLE NONE;contractNumber contractNumber VISIBLE NONE;dateInService dateInService VISIBLE NONE;diameter diameter VISIBLE NONE;diameterUOM diameterUOM VISIBLE NONE;fittingType fittingType VISIBLE NONE;installationCode installationCode VISIBLE NONE;isCUI isCUI VISIBLE NONE;maximoIDFK maximoIDFK VISIBLE NONE;projectID projectID VISIBLE NONE;utilityOwner utilityOwner VISIBLE NONE;createdDate createdDate VISIBLE NONE;createdBy createdBy VISIBLE NONE;lastEditedBy lastEditedBy VISIBLE NONE;lastEditedDate lastEditedDate VISIBLE NONE;sdsID sdsID VISIBLE NONE;Shape Shape VISIBLE NONE")
... # Process: Select Layer By Location
... arcpy.SelectLayerByLocation_management('GasUtilNode_Segment', 'BOUNDARY_TOUCHES', r'P:\YU_Restricted\Yuma_Admin\Projects\FY18\WO18_100_199\18-190_Gas_Utilities_Update_(Plicka_Joffre)\Gas_Utilites.gdb\UTILITIES_GAS\Fitting2Layer', '#', 'NEW_SELECTION', 'NOT_INVERT')
... # Process: Copy Features
... arcpy.CopyFeatures_management(GasUtilNode_Segment__3_, results_shp, '#', "0", "0", "0")
... # Process: Get Count
... arcpy.GetCount_management(results_shp)
... lyrfile = r"P:\\YU_Restricted\\Yuma_Admin\\Projects\\FY18\\WO18_100_199\\18-190_Gas_Utilities_Update_(Plicka_Joffre)\\results.shp"
... result = arcpy.GetCount_management(lyrfile)
... count = int(result.getOutput(0))
... calcuFld = count
... # Process: Calculate Field
... arcpy.CalculateField_management ("GasUtilNode_gControlFitting","mediaID",calcuFld)
... # Process: Delete
... arcpy.Delete_management(r'P:\YU_Restricted\Yuma_Admin\Projects\FY18\WO18_100_199\18-190_Gas_Utilities_Update_(Plicka_Joffre)\results.shp', 'ShapeFile')
... arcpy.Delete_management("Fitting2")
JakeSkinner
Esri Esteemed Contributor
Hi Jesus,
You can use a Search Cursor to iterate through your feature class.  You can specify "OID@" to retrieve the OBJECTID value.  You can add the rest of your code within this FOR loop.  Ex:
with arcpy.da.SearchCursor(fc, ["OID@"]) as cursor:
  for row in cursor:
    arcpy.MakeFeatureLayer(fc, "fcLyr", "OBJECTID = " + row[0])
    arcpy.SelectLayerByLocation‍‍‍‍‍‍‍‍‍...
    arcpy.CopyFeatures...
    arcpy.GetCount....
JoshuaBixby
MVP Esteemed Contributor
The only suggestion I would make is to create the feature layer outside of the loop.  I have found calling Make Feature Layer within a loop when only working with 1 data set tends to create both performance and memory management issues.
JAJoffre
Once I get it up and running I will create a feature layer outside of the loop. This computer is slow!!!!!!!!!!!
JAJoffre
Thank You I will work on it first thing tomorrow and probably run into more problems.
