Hello! I'm trying to use the parameter "GPGASearchNeighborhood" in a tool in my toolbox. I noticed that some of the tools in the Geostatistical Analyst toolbox (for example, Radial Basis Functions interpolation method) limit the options of neighborhood types to 2 out of the default 4 - Standard and Standard Circular (sorry that all the text is in Russian)
Does anyone know how can I do that? I tried using filters, but I can't figure out how to use them with GPGASearchNeighborhood.
#Parameter definition
param8 = arcpy.Parameter(
displayName="GA Neighborhood",
name="ga_neighborhood",
datatype="GPGASearchNeighborhood",
parameterType="Optional",
direction="Input")
#Trying to index just the type like in a multiValue parameter
param8[0].filter.type = "ValueList"
param8[0].filter.list = ["Standard", "StandardCircular"]
#Results in "TypeError: 'Parameter' object does not support indexing"
#Trying to just filter parameter as is
param8.filter.type = "ValueList"
param8.filter.list = ["Standard", "StandardCircular"]
#Results in "AttributeError: 'NoneType' object has no attribute 'type'"
havent tried it, but you may have to define them separately, then use the one you want as a choice
SearchNeighborhoodSmooth—ArcGIS Pro | Documentation
the others are defined with examples in the same link space
