How do I export multiple pdfs from DDP with specific page names?
1461
09-04-2018 07:45 AM
JulieHines1
I am trying to export ~250 pdf's from data driven pages. I want each page to have a specific name which is in the attribute table for the layer I am using for DDP. I have the script I am trying to use attached.
LukeWebb
When in the "Data Driven Page Setup" window where you selected the layer to be used as the data driven index, you are able to select a 'Name Field'.
Subsequently, when exporting map, choose the 'Pages' tab, and select the option to export all maps, using a 'name'. When you enter a name into the GUI for your maps, it will then add the name attribute to the end.
For example you enter "Maps_" and it will export "Maps_Map1Name.pdf", Maps_Map2Name.pdf" etc.
