How do I delete a network analyst layer (i.e., Service Area, Closest Facility) using python 3 (ArcGIS Pro)?
6128
13
07-13-2019 06:23 PM
AndrewClark2
I am building a toolbox using Python 3 in ArcGIS Pro 2.4. It involves a series of network analysis processes, including closest facility and service area. I am using arcpy.na.MakeClosestFacilityAnalysisLayer and arcpy.na.MakeServiceAreaAnalysisLayer. I am able to create them no problem, but I am having lots of trouble with manipulating them, including:
  • I cannot select the location where they are stored - they always get placed in the default GDB even though I am trying to put them "in_memory";
  • I cannot name them something meaningful - They always are named ServiceArea1, Service Area2; and
  • I cannot delete the final layer using python (arcpy.Delete_management) once I am done with it - so every time I rerun the syntax it adds a new file with the wrong name (e.g., ServiceArea2) and my tool crashes.
Anyone have any suggestion on how to fix this and make it work correctly? I want to be able to create it in a specified location, name it something that is meaningful and then delete the file when it is done.
Thanks!
Andrew
MelindaMorang
Would it be possible for you to share your facilities with me so I can test your script?  I can't tell from looking at it what's going wrong, but I'd like to get to the bottom of it.  I don't need your network dataset.
AndrewClark2
Hi Melinda,
Here is the file. I have zipped it into Google Drive as a shapefile. Let me know you if you have any issue!
Locations.zip - Google Drive
Thanks so much.
MelindaMorang
Hi Andrew.  Your script works fine with the addition of this line:
ServArea.defaultImpedanceCutoffs = [1]
Seems like you shouldn't need this because all your facilities have explicitly-set break values in the Breaks field, but for some reason it's getting confused.  I'll log a bug on our end to address this item of confusion, but I think if you add this to your code in the part where you're setting the service area properties, you should be good to go.
AndrewClark2
Thank you so much!
