How do I create Line feature from arcgisonline rest (JSON format) output
1160
04-22-2014 04:05 PM
TakeoShibata
I am trying to generate the route feature.
I looked the some example from
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Route_service_with_asynchronous_exec...
So basically get the all points pf paths and make the straight line in order?
So decode JSON by python and make XY Event layer in order the connect between those?
Thank you!
Sample Response from above URL
"geometry": {
                    "paths": [
                                145.06591391900008,
                                -37.86473982999996
                                145.0671000000001,
                                -37.86528999999996
                            ... additional points
                                145.10584000000006,
                                -37.818539999999985
                                145.10498172400003,
                                -37.81844463599998
MattEiben
Do you have access to ArcMap 10.2?  If so, there's actually a built in tool under Conversion Tools -> JSON called "JSON to Features".
I've never used it before, but the description says its designed to be used with the ArcGIS REST API, which sounds exactly like what you're looking for.
Matt
