How do I compare spatial references of extents?
3726
7
01-03-2019 02:17 PM
KylePerri
I am passing an extent into my script tool and I want to check to make sure it is WGS84 and if it isn't I convert it using projectAs; however, when it is WGS84 if I project it the extent's xmin, xmax, ymin, ymax gets messed up. How can I compare them so I don't project it if it's already in decimal degrees? Here is what I have, but it doesn't seem to work:
boundingBox = None
WGS84 = SpatialReference(4326)
# Project our extent to GPS lat long if it is not already
if extent and extent.spatialReference is not WGS84:
    boundingBox = extent.projectAs(WGS84)
JoshuaBixby
MVP Esteemed Contributor
Did you try:
boundingBox = None
if extent and extent.spatialReference == WGS84:
    boundingBox = extent.projectAs(WGS84)‍‍‍‍‍
Your original code used the is operator, which tests for object identity and not equality.  A quick check shows that Esri has implemented equality equivalence with the Spatial Reference class:
>>> SR1 = arcpy.SpatialReference(4326)
>>> SR2 = arcpy.SpatialReference(4326)
>>> SR1 == SR2
True
>>> SR1 is SR2
False
DanPatterson_Retired
can you put in values that you are testing.  the code snippet fails since 'extent' isn't defined
KylePerri
Extent is a parameter in the script tool, but I've been using the current extent of my map.
Then my examples should help if it is an extent object.  If it is a string representation of the extent, you may have some parsing to do to get the numeric values
KylePerri
I ended up doing this:
if extent and extent.spatialReference.linearUnitName == 'Meter':
    boundingBox = extent.projectAs(SpatialReference(4326))
It seems to work.
JoshuaBixby
Did you try:
boundingBox = None
>>> SR1 == SR2
True
>>> SR1 is SR2
False
JoeBorgione
Not sure if these links will help or not:
https://community.esri.com/thread/226543-how-to-output-the-values-of-bounding-box-in-spatial-index-u...
projectAs help
I don't have any experience with projectAs, but I think if you could get the xy's out of the given feature class and then compare their values to a set (or subset) of known values, you should be able to determine if they are DD or something else.
That should just about do it....
An example.... one file in geographic and one in projected coordinates...
in_fc = r"C:\....\arcpytools_demo.gdb\Can_0_big_3"
desc = arcpy.Describe(in_fc)
ext = desc.extent
ext.spatialReference.name
'GCS_WGS_1984'
in_fc2 = r"C:\Git_Dan\a_Data\testdata.gdb\polygon"
desc2 = arcpy.Describe(in_fc2)
ext2 = desc2.extent
ext2.spatialReference.name
'NAD_1983_CSRS_MTM_9'
# ----- now do the comparisons ----
ext.spatialReference.name  # ---- 'GCS_WGS_1984'
ext.lowerLeft
<Point (-141.00686645507812, 41.67692565917997, #, #)>
ext.upperRight
<Point (-52.61888885498041, 83.11042022705101, #, #)>
ext2.spatialReference.name  # ---- 'NAD_1983_CSRS_MTM_9'
ext2.lowerLeft
<Point (300000.0, 5000000.0, #, #)>
ext2.upperRight
<Point (300020.0, 5000020.0, #, #)>
# ---- now other properties and test parameters ----
ext.contains(ext2)
True
ext2.contains(ext)
False
ext.overlaps(ext2)
False
ext.within(ext2)
False
ext2.within(ext)
True
# ----- from the help
dir(ext)
['JSON', 'MMax', 'MMin', 'XMax', 'XMin', 'YMax', 'YMin', 'ZMax', 'ZMin',.... snip...
 ', 'contains', 'crosses', 'depth', 'disjoint', 'equals', 'geohash', 'geohashCovers',
 'geohashNeighbors', 'height', 'lowerLeft', 'lowerRight', 'overlaps', 'polygon',
 'projectAs', 'spatialReference', 'touches', 'upperLeft', 'upperRight', 'width',
 'within']
