How do I calculate a field using sequential numbers but maintain a defined number of digits?
1869
12-20-2019 05:55 AM
JimNoble
I'd like to create a field of sequential numbers starting at 001 counting all the way until 322. Every number must be 3 digits. How do I do this?
Thank you all for your help.
JakeSkinner
Esri Esteemed Contributor
Hi James,
You can do this using the Field Calculator.  Here is an example:
rec=0
def autoIncrement():
 global rec
 pStart = 1 #adjust start value, if req'd
 pInterval = 1 #adjust interval value, if req'd
 if (rec == 0):
  rec = pStart
 else:
  rec = rec + pInterval
 if len(str(rec)) == 1:
     return "00" + str(rec)
 elif len(str(rec)) == 2:
     return "0" + str(rec)
 elif len(str(rec)) == 3:
     return str(rec)
JakeSkinner
Hi James,
rec=0
 global rec
 if (rec == 0):
  rec = pStart
 else:
     return str(rec)
JimNoble
Thanks Jake. That's perfect!
JoshuaBixby
MVP Esteemed Contributor
Another approach, instead of using global variables, is to use a generator:
Code Block:
def gen(x=0):
    while True:
        yield "{:0=3}".format(x)
        x+=1
g = gen()
Expression:
next(g)
