How can I write a python add-in which zooms to each selected polygon after each button click?
3430
07-02-2015 11:25 AM
RobertBuckley1
I want to have a button in a toolbar which when clicked, zooms to the extent of the next selected polygon. I am not sure whether this tool has been developed yet (although i´m sure it has) and do not know whether it should be a python button, or tool class.
Following code creates a list of selected elements. I want to go to the next row after each mouse click.
mxd = arcpy.mapping.MapDocument('CURRENT')
df = arcpy.mapping.ListDataFrames(mxd, "Layers") [0]
Envelopes = [] # store extents here
# find the selection set
SelLayer = arcpy.mapping.ListLayers(mxd,data_frame=df)[0] # first layer
fidSet = arcpy.Describe(SelLayer).FIDSet
if len(fidSet) == 0:
  arcpy.AddMessage("Nothing selected")
else:
  # now cursor through it an get the geometries
  # storing their extents into a list
  with arcpy.da.SearchCursor(SelLayer,"SHAPE@") as SCur:
  for feat in SCur:
  # I'm going to assume polygon/polyline
  Envelopes.append(feat[0].extent) # grab the envelope
  df.extent = Envelopes[0] # first extent
  arcpy.RefreshActiveView()
The code creates the list, but how can I use a button zoom to the next row extent?
Tags (1)
WesMiller
You could create a layer file from your selected features then use the data driven pages toolbar to move forward and backward through your feature layer.
DavidLamb
If you are using a python add-in wizard, you can do something like this. On the first click, you store the envelopes in a class level property. If the list isn't empty then keep going through and setting extents. This worked on my machine running 10.2
import arcpy
import pythonaddins
class ButtonClass1(object):
    """Implementation for zoomto_addin.button (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
        self.mxd = None
        self.df = None
        self.envelopes = []
        self.lastIndex = 0
    def onClick(self):
        print "clicked"
        if len(self.envelopes)<1:
            self.mxd = arcpy.mapping.MapDocument('CURRENT')
            self.df = arcpy.mapping.ListDataFrames(self.mxd, "Layers") [0]
            print "getting stuff"
            SelLayer = arcpy.mapping.ListLayers(self.mxd,data_frame=self.df)[0] # first layer
            else:
                    for feat in SCur:
                        self.envelopes.append(feat[0].extent) # grab the envelope
                print len(self.envelopes)
                self.lastIndex = 0
                self.setExtent
        else:
            self.setExtent()
    def setExtent(self):
        print self.lastIndex
        if self.lastIndex < (len(self.envelopes)-1):
            self.df.extent = self.envelopes[self.lastIndex]
            self.lastIndex += 1
        else:
            self.lastIndex = 0
            self.lastIndex += 1
