How can I set my tool boolean parameter to true in my arcpy script?
2709
02-02-2022 05:53 PM
tzz_12
I have set one my ArcGIS Pro tool's parameter as optional to auto populate a field ID if the field ID is missing. However, when I tried to populate the field ID, it does not work. How do I set my boolean parameter to true in my script to populated the required ID field?  (On a side note, the "with arcpy.da.SearchCursor" block is meant to search in the first row of the column, OBJECTID to determine if it is zero; if the condition is true, then it will calculate the field ID with "!OBJECTID!+1" and if not, it will use "!OBJECTID!", because the ID needs to start with 1. Is there a better way of writing this part of the script? Not my main question, but just curious for other suggestion. Thanks everyone! )
CreatePPTFieldID = arcpy.GetParameterAsText(8)
#Creating the field ID
if (CreatePPTFieldID = "True"):
   arcpy.management.AddField(inpourpoint,"ID","Long")
   with arcpy.da.SearchCursor(inpourpoint, 'OBJECTID') as cursor:
      for row in cursor:
         if (row[0]==0):
            arcpy.CalculateField_management(inpourpoint,"ID","!OBJECTID!+1")
            exit()
        else:
           arcpy.CalculateField_management(inpourpoint,"ID","!OBJECTID!")
           exit()
DanPatterson
MVP Esteemed Contributor
(CreatePPTFieldID = "True") is an assignment statement
(CreatePPTFieldID == "True") is a condition statement
throw in a print statement to make sure it is returning a text string ("True" ) and not a boolean ( True )
exit() isn't needed
... sort of retired...
Tomasz_Tarchalski
@DanPattersonI think the respond is a few lines before. tzz_12 when you are getting values from toolbox, you can get the variables as TEXT or as 'they are'. so try instead
CreatePPTFieldID = arcpy.GetParameter(8)
