How can I force a python toolbox to refresh?
9878
7
08-13-2014 11:46 AM
YuvalHadas
In order to ease the entry of the parameters, whenever the toolbox is opened, the latest parameters are being read from a table, and if changed are saved back. The problem is that the toolbox must be manually refreshed every time for the parameters to be displayed correctly.
def getParameterInfo(self):
cursor = arcpy.da.SearchCursor("Parameters", ['data_set', 'date_p', 'from_p', 'to_p', 'location_p', 'wait_p', 'distance_p'])
for row in cursor:
  ds=row[0]
  date_p=row[1]
  from_p=row[2]
  to_p=row[3]
  location_p=row[4]
  wait_p=row[5]
  distance_p=row[6]
  l_ds="results-"+ds
param0 = arcpy.Parameter(
  displayName="Destinations",
  name="in_destinations",
  datatype="GPString",
  parameterType="Required",
  direction="Input")
param0.filter.type = "ValueList"
values = [row[0] for row in arcpy.da.SearchCursor(l_ds, ("location"))]
param0.value=location_p
lst = list(set(values))
lst.sort()
param0.filter.list = lst
def execute(self, parameters, messages):
arcpy.env.workspace =""
location_p=parameters[0].valueAsText
date_p=parameters[1].valueAsText
from_p=parameters[2].valueAsText
to_p=parameters[3].valueAsText
wait_p=parameters[4].valueAsText
distance_p=parameters[5].valueAsText
cursor = arcpy.da.UpdateCursor("Parameters", ['date_p', 'from_p', 'to_p', 'location_p', 'wait_p', 'distance_p'])
for row in cursor:
  row[0]=date_p
  row[1]=from_p
  row[2]=to_p
  row[3]=location_p
  row[4]=wait_p
  row[5]=distance_p
  cursor.updateRow(row)
Tags (3)
JasonScheirer
Esri Alum
Do it in the updateParameters method.
    with arcpy.da.SearchCursor("Parameters", ['location_p']) as cursor:
      for row in cursor:
        location_p = row[0]
      direction="Input")
    param0.filter.list = []
    param0.value = location_p
    return [param0]
def updateParametrs(self, parameters)
    param0 = parameters[0]
    with arcpy.da.SearchCursor("Parameters", ['data_set']) as cursor:
      for row in cursor:
        l_ds = "results-" + row[0]
    values = sorted(set([row[0] for row in arcpy.da.SearchCursor(l_ds, ("location"))]))
    param0.filter.list = values
YuvalHadas
I think I was not clear with the problem.
Parameter A's value in the file is "0" (from previous execution).
Toolbox is being refreshed from the catalog window.
First execution of the toolbox. Parameter A default value is being read from the file. On screen default value is "0". Parameter A is set to "1". The rest of execution is with value "1". Value "1" is updated to the file.
Second execution of the toolbox. Parameter A default value is being read from the file. On screen default value is "0" (should have been "1"). Parameter A is set to "2". The rest of execution is with value "2". Value "2" is updated to the file.
Third execution of the toolbox. Parameter A default value is being read from the file. On screen default value is "2" (due to refresh)...
JasonScheirer
Esri Alum
This is not directly supported in the geoprocessing framework. You could get around it by writing the name of the data to a file in .execute and having the .getParameterInfo() read it when it loads.
YuvalHadas
I believe that this is what I've done. the .getParameterInfo() loads the data, while the .execute() saves the data. As I stated, the data is saved and executed correctly, but it does not assigned as default value, unless I refresh the toolbox.
class select_data(object):
  def __init__(self):
  """Define the tool (tool name is the name of the class)."""
  self.label = "Select Data"
  self.description = ""
  self.canRunInBackground = False
  """Define parameter definitions"""
  cursor = arcpy.da.SearchCursor("Parameters", ['data_set'])
  for row in cursor:
  ds=row[0]
  displayName="File",
  name="in_file",
  direction="Input")
  param0.value=ds
  params = [param0]
  return params
  def isLicensed(self):
  """Set whether tool is licensed to execute."""
  return True
  def updateParameters(self, parameters):
  """Modify the values and properties of parameters before internal
  validation is performed.  This method is called whenever a parameter
  has been changed."""
  return
  def updateMessages(self, parameters):
  """Modify the messages created by internal validation for each tool
  parameter.  This method is called after internal validation."""
  return
  """The source code of the tool."""
  cursor = arcpy.da.UpdateCursor("Parameters", ['data_set'])
  for row in cursor:
  row[0]=parameters[0].valueAsText
  ds="-"+parameters[0].valueAsText
  stp1=arcpy.mapping.Layer("direct_xfer_trips")
  stp2=arcpy.mapping.Layer("direct_trips")
  stp3=arcpy.mapping.Layer("xfer_trips")
  stp4=arcpy.mapping.Layer("xfer_pot")
  mxd = arcpy.mapping.MapDocument("CURRENT")
  stp1.replaceDataSource("shape_files","SHAPEFILE_WORKSPACE","stops"+ds)
  stp2.replaceDataSource("shape_files","SHAPEFILE_WORKSPACE","stops"+ds)
  stp3.replaceDataSource("shape_files","SHAPEFILE_WORKSPACE","stops"+ds)
  stp4.replaceDataSource("shape_files","SHAPEFILE_WORKSPACE","stops"+ds)
  del mxd
  return
BillDaigle
The problem is... the 'getParameters' function only runs once -- when the toolbox is refreshed.  In order to do what you want without refreshing, you will need to use the 'updateParameters' functions, as Jason Scheirer​ suggested.  This runs every time a parameter is updated. I'm not sure if it will run as soon as you open the tool.  If not, you could add another Boolean parameter that trigger the "Update from Table" and disable the parameter once the parameters have been updated.
CharlesGasse1
Here is a way you can refresh a python toolbox:
Python toolbox doesn't want to refresh
Have a good day.
Charles
Luke_Pinner
MVP Regular Contributor
The OP's question is referring to running a tool from ArcToolbox and my answer to your question about running a tool from a Python Addin using the pythonaddins.GPToolDialog won't work here.
