I'm working on a script/tool for a python addin that will let me create a replicas, one at a time per tool run, but to different locations. Another script will allow me to sync the replicas. These will be one-way replicas, from a SQL SDE to file GDBs. Currently I am using ArcGIS Desktop 10.3.1 advanced, SDE SQL2008.
In theory, this will be done once for each location and I will probably include an attribute so I can control the replica name.
If by chance I mess up and use the same name for a replica, I will get an (expected) error:
PYTHON ERRORS:
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 808, in CreateReplica
raise e
<class 'arcgisscripting.ExecuteError'>: ERROR 000775: Replica with the same name already exists.
Failed to execute (CreateReplica).
GP ERRORS:
Q1: How can I test whether the replica already exists (so I can exit cleanly with message)? Also, I would want to use a similar test before I try to sync.
Q2: Is there a way in python/arcpy to list all the replicas that currently exist? (additional info would be nice, but not mandatory)
Thanks
tagging Geodatabase
