How cam i use a arcpy script to get the login name of the system user
1655
09-07-2012 09:00 PM
OLANIYANOLAKUNLE
How cam i use a arcpy script to get the login name of the system user and use the name to pupolate a field in a feature attribute table?
AlessandroCinnirella
import os name = os.environ.get('USERNAME') print name
once you get the name in the variable you can populate any attribute table using an insert or an update cursor
ciao,
AC
ciao,
AC
OLANIYANOLAKUNLE
Thanks that did it!
OLANIYANOLAKUNLE
Re: How can i use a arcpy script to get the login name of the system user
