Hello!
I hope someone will understand what I want. I will try to make it as clear as possible
I am begginer in programming and want to make is a tool that would cluster lines. Because client want to have better overview of schema. There is two things I would like to do. One is making one line out of more in certain buffers around them and attach all atributes to that line. Other is to separate lines by specific buffer. So basicly if one line is, lets say 5 meters from other, cluster it with other one and show as one(probably in middle distance of these two and attach attributes of both) or, in other case, move away second line so its out of buffer zone of other.
Is this possible to do?
Please, if you have advice share with me.
Thank you
