Help with layer file definition query in arcpy.mapping
1855
5
08-20-2013 11:20 AM
GerryGabrisch
Everything seems to work just fine with the code below except that no features draw in the layer that is being queried.  All I want to do is create a jpeg for each record in my geodatabase feature class of point locations.
Is there something wrong with my query syntax?  I cannot figure it out!
try:
    import arcpy, sys, traceback
    print "Working..."
    mxdPath = r"Z:\GISpublic\GerryG\WaterResources\WaterSampleSiteAutoMap\WaterSampleSiteAutoMap2.mxd"
    mxd = arcpy.mapping.MapDocument(mxdPath)
    df = arcpy.mapping.ListDataFrames(mxd)[0]
    lyr = arcpy.mapping.ListLayers(mxd, "WaterSampleSiteMaster", df)[0]
    print lyr.dataSource
    theAttribute = "SiteID"
    #GetAListOfEachAttribute
    listOfAttributes = []
    print "Start cursor"
    rows = arcpy.SearchCursor(lyr.dataSource)
    for row in rows:
        listOfAttributes.append(row.getValue(theAttribute))
    for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
        if elm.name == 'gbglabeler':
            elm = elm
            print elm.name
            break
    for item in listOfAttributes:
        #GBGquery = "\""  + theAttribute + "\" = " + "'" + item + "'"
        GBGquery = '"SiteID" =' + '\''+ item + '\''
        print  "Working on: ",item
        print GBGquery
        lyr.definitionQuery = GBGquery
        elm.text = "Site: " + item
        outputjpg = "Z:\GISpublic\GerryG\WaterResources\WaterSampleSiteAutoMap\SiteMaps\\" + item + ".jpg"
        arcpy.RefreshActiveView()
        arcpy.mapping.ExportToJPEG (mxd, outputjpg)
    print "done"
except arcpy.ExecuteError:
    msgs = arcpy.GetMessages(2)
    arcpy.AddError(msgs)
#If the error is with the script, or with python, find error and report it to the screen...
except:
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
    msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    arcpy.AddError(pymsg)
MattSayler
Long time no see!
Starting with the basics, is SiteID a text field (does the value need the single quotes)? Is the query working if you manually assign it to the layer?
Since it's running without error, I suspect this won't help, but you could also try using the Add Field Delimeters method for the field name:
GBGquery = arcpy.AddFieldDelimiters(lyr, theAttribute) + " = '" + item + "'"
GerryGabrisch
Thanks for the reply, Matt.  I hope you are doing well.
Yes, SiteID is an attribute storing text.
I tried the field delimeter but that just returned the same text string as the brute force way and nothing showed on the output jpeg.  Any other thoughts?
GerryGabrisch
Hmmm, Must have been some hang up between Arcpy, Komodo, ArcGIS or Citrix.
I tried to save the original mxd, got an error that the file location folder was in use.  After shutting ArcMap and Komodo down the original code worked fine.
MattSayler
Is it just the JPEGs that aren't displaying the layer correctly? Step through using mxd = arcpy.mapping.MapDocument("CURRENT"), if you haven't already. Try exporting to pdf or one of the other formats too and see if you get the same results.
MattSayler
Excellent!
