Help me please arcpy will not initiallize
1339
09-17-2013 11:53 AM
EdwardTanas
Using Python Idle
typed in
import arcpy
get error below
  File "<pyshell#3>", line 1, in <module>
    import arcpy
ImportError: No module named arcpy
using
Python 2.7.3 (default, Apr 10 2012, 23:24:47) [MSC v.1500 64 bit (AMD64)] on win32
using Arcis 10.1
thank you
T__WayneWhitley
Honored Contributor
See the bottom of this page concerning 'paths and import':
Importing ArcPy
Desktop » Geoprocessing » Python
http://resources.arcgis.com/en/help/main/10.1/index.html#//002z00000008000000
Enjoy,
Wayne
StacyRendall1
I would guess you are not using the Python installed by ArcGIS. It is possible (but I think unlikely) that somehow the *.pth file got lost or messed up, but if it did Waynes solution will help.
You could end up using the wrong Python if you already had it installed, or installed another Python after ArcGIS.
The IDLE associated with ArcGIS Python is found here:
Start Menu ... > ArcGIS > Python ... > IDLE (Python GUI)
You can check the paths available to Python in IDLE with:
File > Path Browser
EdwardTanas
File > Path Browser
____________________________________________________________________
thank you so very much....to Stacy Rendall
That was the exact issue....
