Help improving tool
4126
10
02-25-2014 05:58 AM
TonyAlmeida
MVP Regular Contributor
I have this script that i have put into a tool but it runs super slow. it take about 4 minutes to create a point and populate.
The tool does not give me an error it's just super slow, I believe it is taking all the the testParcelsAdmit and putting them into memory instead of just the on that pertains to the point. I've been struggling with this too script for a while so if anyone could PLEASE help me improve this tool i would gratefully appreciate it.
here is the script i am working with.
import arcpy
import pythonaddins
import os
from arcpy import env
class Add_points(object):
    """Implementation for AddPoints_addin.Add_points (Tool)"""
    def __init__(self):
        self.enabled = True
        self.cursor = 3 # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
    def onMouseDownMap(self, x, y, button, shift):
        fc = "TonyTwoWay.DBO.TT"
        workspace = r"C:\Users\talmeida\AppData\Roaming\ESRI\Desktop10.1\ArcCatalog\Connection to dsd15_sqlexpress.sde"
        #arcpy.ChangeVersion_management('TonyTwoWay.DBO.TT','TRANSACTIONAL','dbo.DEFAULT', "")
        # Start an edit session. Must provide the worksapce.
        edit = arcpy.da.Editor(workspace)
        # Edit session is started without an undo/redo stack for versioned data
        #  (for second argument, use False for unversioned data)
        edit.startEditing(True)
        # Start an edit operation
        edit.startOperation()
        CC_list = []
        with arcpy.da.SearchCursor(fc, ["AddressID"]) as cursor:
            for row in cursor:
                try:
                    if "CC" in row[0]:
                        CC_list.append(int(row[0].strip("CC")))
                except TypeError:
                    pass
        del cursor
        CC_list.sort()
        AddressID = CC_list[-1] + 1
        AddressID = 'CC' + str(AddressID)
        row_values = [(x, y, (x, y), AddressID)]
        cursor = arcpy.da.InsertCursor(fc, ["X_Coord", "Y_Coord", "SHAPE@XY", "ADDRESSID"])
        for row in row_values:
            cursor.insertRow(row)
        del cursor
                 # Stop the edit operation.
        edit.stopOperation()
        # Stop the edit session and save the changes
        edit.stopEditing(True)
        arcpy.RefreshActiveView()
        fcTarget = "TonyTwoWay.DBO.TT"
        fcJoin = "testParcelsAdmit"
        add_fields = ["ACCOUNT","SiteNum","OwnerName","SiteAddres","SiteNumSfx","SiteStreet","predir","StreetType","SubName"]
        # fix args
        if not isinstance(add_fields, list):
            # from script tool
            add_fields = add_fields.split(';')
        # do not need this scratch file
        fcOutput = r'in_memory\temp_join'
        arcpy.SpatialJoin_analysis(fcJoin, fcTarget,fcOutput, 'JOIN_ONE_TO_MANY')
        # grab oid field from points
        oid_t = arcpy.Describe(fcTarget).OIDFieldName
        # init rowW and rowR
        curR = arcpy.SearchCursor(fcOutput)
        join_dict = dict([(r.JOIN_FID,[r.getValue(f) for f in add_fields]) for r in curR])
        del curR
        # Now update the new target
        curW = arcpy.UpdateCursor(fcTarget)
        for row in curW:
            t_oid = row.getValue(oid_t)
            if t_oid in join_dict:
                for f in add_fields:
                    row.setValue(f, join_dict[t_oid][add_fields.index(f)])
            curW.updateRow(row)
        del row, curW
        arcpy.AddMessage('Updated all records sucussefully')
        pass
TonyAlmeida
jamesfreddyc thank you for your input, i can see how the time model would be very helpful.
If i can just get this to work. being a newbie and trying to learn python...
