Help improving tool
4115
10
02-25-2014 05:58 AM
TonyAlmeida
MVP Regular Contributor
I have this script that i have put into a tool but it runs super slow. it take about 4 minutes to create a point and populate.
The tool does not give me an error it's just super slow, I believe it is taking all the the testParcelsAdmit and putting them into memory instead of just the on that pertains to the point. I've been struggling with this too script for a while so if anyone could PLEASE help me improve this tool i would gratefully appreciate it.
here is the script i am working with.
import arcpy
import pythonaddins
import os
from arcpy import env
class Add_points(object):
    """Implementation for AddPoints_addin.Add_points (Tool)"""
    def __init__(self):
        self.enabled = True
        self.cursor = 3 # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
    def onMouseDownMap(self, x, y, button, shift):
        fc = "TonyTwoWay.DBO.TT"
        workspace = r"C:\Users\talmeida\AppData\Roaming\ESRI\Desktop10.1\ArcCatalog\Connection to dsd15_sqlexpress.sde"
        #arcpy.ChangeVersion_management('TonyTwoWay.DBO.TT','TRANSACTIONAL','dbo.DEFAULT', "")
        # Start an edit session. Must provide the worksapce.
        edit = arcpy.da.Editor(workspace)
        # Edit session is started without an undo/redo stack for versioned data
        #  (for second argument, use False for unversioned data)
        edit.startEditing(True)
        # Start an edit operation
        edit.startOperation()
        CC_list = []
        with arcpy.da.SearchCursor(fc, ["AddressID"]) as cursor:
            for row in cursor:
                try:
                    if "CC" in row[0]:
                        CC_list.append(int(row[0].strip("CC")))
                except TypeError:
                    pass
        del cursor
        CC_list.sort()
        AddressID = CC_list[-1] + 1
        AddressID = 'CC' + str(AddressID)
        row_values = [(x, y, (x, y), AddressID)]
        cursor = arcpy.da.InsertCursor(fc, ["X_Coord", "Y_Coord", "SHAPE@XY", "ADDRESSID"])
        for row in row_values:
            cursor.insertRow(row)
        del cursor
                 # Stop the edit operation.
        edit.stopOperation()
        # Stop the edit session and save the changes
        edit.stopEditing(True)
        arcpy.RefreshActiveView()
        fcTarget = "TonyTwoWay.DBO.TT"
        fcJoin = "testParcelsAdmit"
        add_fields = ["ACCOUNT","SiteNum","OwnerName","SiteAddres","SiteNumSfx","SiteStreet","predir","StreetType","SubName"]
        # fix args
        if not isinstance(add_fields, list):
            # from script tool
            add_fields = add_fields.split(';')
        # do not need this scratch file
        fcOutput = r'in_memory\temp_join'
        arcpy.SpatialJoin_analysis(fcJoin, fcTarget,fcOutput, 'JOIN_ONE_TO_MANY')
        # grab oid field from points
        oid_t = arcpy.Describe(fcTarget).OIDFieldName
        # init rowW and rowR
        curR = arcpy.SearchCursor(fcOutput)
        join_dict = dict([(r.JOIN_FID,[r.getValue(f) for f in add_fields]) for r in curR])
        del curR
        # Now update the new target
        curW = arcpy.UpdateCursor(fcTarget)
        for row in curW:
            t_oid = row.getValue(oid_t)
            if t_oid in join_dict:
                for f in add_fields:
                    row.setValue(f, join_dict[t_oid][add_fields.index(f)])
            curW.updateRow(row)
        del row, curW
        arcpy.AddMessage('Updated all records sucussefully')
        pass
DuncanHornby
MVP Notable Contributor
Tony,
One comment I can make is that you start with the new faster da.cursor then swap back to the slower old style cursor after the ####... line
I would recommend as a first stab at improving the speed to change your cursor types.
Duncan
JamesCrandall
When confronted with performance issues, I like to implement timers along the way at various processing points to get a good idea of where bottlenecks are occuring.  You do get fancy with it, or just put in print statements strategically and run a stopwatch to see where things slow down.
Use the in_memory workspace where possible: typically I see 1/2 the time to process things there compared to disk reads/writes.
Here's a time class you can use.  Put it at the very top of your script:
class Timer:
    def __enter__(self):
        self.start = time.clock()
        return self
    def __exit__(self, *args):
        self.end = time.clock()
        self.interval = self.end - self.start
Usage:
   t = Timer()
   with t:
        CC_list.sort()
        del cursor
   timetest = completed in %.02f secs." % (t.interval)
   print timetest
TonyAlmeida
Thank you both for your reply. i have changed both search cursor to arcpy.da.searchCursor.
I am getting an error in the timer.
  File "C:\Users\talmeida\AppData\Local\ESRI\Desktop10.1\AssemblyCache\{BB229966-100D-4482-A3FE-B298BD262597}\AddPoints_addin.py", line 65
SyntaxError: invalid syntax
current code
import arcpy
import pythonaddins
import os
class Timer:
                return self
    def __init__(self):
        self.enabled = True
        CC_list = []
            for row in cursor:
                try:
                    if "CC" in row[0]:
                except TypeError:
                    pass
        del cursor
        t = Timer()
        with t:
             CC_list.sort()
             del cursor
        print timetest
        # fix args
            # from script tool
        curR = arcpy.da.SearchCursor(fcOutput)
        del curR
        for row in curW:
            curW.updateRow(row)
        del row, curW
        pass
Changing just the SEarch Cursor to arcpy.da.SearchCursor
I get this error,
  File "C:\Users\talmeida\AppData\Local\ESRI\Desktop10.1\AssemblyCache\{BB229966-100D-4482-A3FE-B298BD262597}\AddPoints_addin.py", line 74, in onMouseDownMap
TypeError: Required argument 'field_names' (pos 2) not found
Just Search Cursor change to arcpy.da.SearchCursor
import arcpy
import pythonaddins
import os
    def __init__(self):
        self.enabled = True
        CC_list = []
            for row in cursor:
                try:
                    if "CC" in row[0]:
                except TypeError:
                    pass
        del cursor
        CC_list.sort()
        del cursor
        # fix args
            # from script tool
        del curR
        for row in curW:
            curW.updateRow(row)
        del row, curW
        pass
MathewCoyle
Honored Contributor
For the second the da cursors have a different parameter format. Review the ArcGIS documentation of cursors.
http://resources.arcgis.com/en/help/main/10.2/index.html#//018w00000011000000
GerryGabrisch
I have had good luck speeding up tools with 64-bit background geoprocessing.
http://resources.arcgis.com/en/help/main/10.1/index.html#//002100000040000000
TonyAlmeida
mzcoyle i did import the time model but i got the following error,
I am not understand how to emplement the second arcpy.da.searchCursor with the spatial join. Sorry python newbie here.
gabrisch i will look into 64-bit background geoprocessing.
JamesCrandall
You are missing the quote at the begining:
timetest = "completed in %.02f secs." % (t.interval)
TonyAlmeida
jamesfreddyc after adding the quote i ran and  the script.
I get no error but now the points are not being populated anymore...?
Python window
completed in 0.05 secs.
completed in 0.03 secs.
completed in 0.07 secs.
completed in 0.04 secs.
completed in 0.08 secs.
JamesCrandall
Python window
If you believe the Timer code is causing this, then remove it.  It's just a suggestion to determine the processing time for things, and it seems to work for you now, but I am not sure how it could cause other code to no longer work.
