Hello. I am very green with Python. I'm trying to create a series of maps using the time slider. I found a script that works (produces the maps in PDF), but the extent is incorrect and the resolution is low. Help... understanding that I'm very new to Pyth
839
03-03-2017 09:18 AM
DaveWatson1
This is my script
>>> import arcpy
... import os
... mxd = arcpy.mapping.MapDocument(r"G:\GIS\Maps\Projects.mxd")
... df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
... df.time.currentTime = df.time.startTime
... while df.time.currentTime <= df.time.endTime:
... # An example str(newTime) would be: "2008-12-29 02:19:59"
... # The following line splits the string at the space and takes the first
... # item in the resulting string.
... fileName = str(df.time.currentTime).split(" ")[0] + ".pdf"
... arcpy.mapping.ExportToPDF(mxd, os.path.join(r"G:\GIS\GIS_Analysis\CS_Working_Group\Time Maps", fileName), df)
... df.time.currentTime = df.time.currentTime + df.time.timeStepInterval
... del mxd
