having trouble renaming and updating layers
1571
09-14-2011 05:24 AM
FrankVignati
in the following script all processes run fin until it gets to the remove, renmame, and update layers commands, however if the commands are put into a seperate script and run everything goes fine
it would be best if it could run as one script, any help would be appreciated:
the script where it fails:
## Import standard modules
import sys, os
## Set the necessary product code
import arcinfo
## Import arcpy module and environment module
import arcpy
import arcpy.mapping
from arcpy import env
## Set the output workspace
arcpy.env.workspace = r"G:\AGIS\2011\Special_Projects\Dist_1\Dieldrin_Well_Sampling\DieldrinParcelData.gdb\ParcelData"
## Overwrite pre-existing files
arcpy.env.overwriteOutput = True
## Sets the MXD file
IMXD = arcpy.mapping.MapDocument("CURRENT")
## Sets the Dataframe
DF = arcpy.mapping.ListDataFrames(IMXD, "Layers")[0]
Date = arcpy.GetParameterAsText(0)
NewSampleData = arcpy.GetParameterAsText(1)
PastSample = arcpy.GetParameterAsText(2)
NameStart = NewSampleData.rfind("\\") + 1
AddNewLayer = str(NewSampleData[NameStart:])
arcpy.MakeFeatureLayer_management(NewSampleData, AddNewLayer)
arcpy.SetParameterAsText(3,AddNewLayer)
arcpy.RefreshTOC()
Selection = "\"SAMPLE\" <> '' AND \"SAMPLE\" <> ' ' AND \"SAMPLE\" <> 'C' "
arcpy.SelectLayerByAttribute_management(AddNewLayer, "NEW_SELECTION", Selection)
SelectedSamples = arcpy.MakeFeatureLayer_management(AddNewLayer, "SelectedSamples")
arcpy.SetParameterAsText(4, SelectedSamples)
arcpy.RefreshTOC()
arcpy.SelectLayerByLocation_management("Volusia_Parcels", "INTERSECT", "SelectedSamples")
SelectedParcels = arcpy.MakeFeatureLayer_management("Volusia_Parcels", "SelectedParcels")
arcpy.SetParameterAsText(5, SelectedParcels)
arcpy.RefreshTOC()
OutParcels = r"Parcels_%s"%(Date)
arcpy.SpatialJoin_analysis("SelectedParcels", "SelectedSamples", OutParcels, "JOIN_ONE_TO_ONE", "KEEP_ALL")
NewParcels = arcpy.MakeFeatureLayer_management(OutParcels, "NewParcelLayer")
arcpy.SetParameterAsText(6, NewParcels)
JoinLayer = arcpy.mapping.ListLayers(IMXD, PastSample,DF)[0]
arcpy.AddJoin_management(NewParcels, "ALTKEY", JoinLayer, "ALTKEY", "KEEP_ALL")
ChangeSelection = r"%s.SAMPLE <> %s.SAMPLE"%(OutParcels, PastSample)
arcpy.SelectLayerByAttribute_management(NewParcels, "NEW_SELECTION", ChangeSelection)
arcpy.RemoveJoin_management(NewParcels, PastSample)
OutSample = r"Parcels_Changed_%s"%(Date)
arcpy.CopyFeatures_management(NewParcels, OutSample)
NewChanges = arcpy.MakeFeatureLayer_management(OutSample, "NewParcelChanges")
arcpy.SetParameterAsText(7, NewChanges)
########## These changes do not take effect ######################
arcpy.AddMessage("Removing Layers")
for ILayer in arcpy.mapping.ListLayers(IMXD):
   if ILayer.name == "SelectedSamples":
       arcpy.mapping.RemoveLayer(DF, ILayer)
   if ILayer.name == "SelectedParcels":
arcpy.AddMessage("Setting Varibles")
PLayer = r"Parcels_%s"%(Date)
CLayer = r"Parcels_Changed_%s"%(Date)
arcpy.AddMessage("Renaming Layers")
  if ILayer.name == "NewParcelLayer":
    ILayer.name = PLayer
  elif ILayer.name == "NewParcelChanges":
    ILayer.name = CLayer
arcpy.RefreshTOC()
IMXD.save()
arcpy.AddMessage("Setting Layer Symbology")
try:
  SymbolLayer1 = arcpy.mapping.Layer(r"G:\AGIS\2011\Special_Projects\Dist_1\Dieldrin_Well_Sampling\DieldrinWellSamples.lyr")
  NewLayer1 = arcpy.mapping.ListLayers(IMXD, PLayer,DF)[0]
  arcpy.mapping.UpdateLayer(DF, NewLayer1, SymbolLayer1)
  SymbolLayer2 = arcpy.mapping.Layer(r"G:\AGIS\2011\Special_Projects\Dist_1\Dieldrin_Well_Sampling\Parcels_Changed.lyr")
  NewLayer2 = arcpy.mapping.ListLayers(IMXD, CLayer,DF)[0]
  arcpy.mapping.UpdateLayer(DF, NewLayer2, SymbolLayer2)
except:
  arcpy.GetMessages()
############### All STOP #########################
## Refresh map
arcpy.RefreshTOC()
arcpy.RefreshActiveView
IMXD.save()
this script works if run after the previous one:
import sys, os
import arcinfo
import arcpy
arcpy.RefreshTOC()
## Refresh map
arcpy.RefreshTOC()
IMXD.save()
FrankVignati
any help? am i missing a step?
NAOMIPAUL
Did you every resolve this? We are having a similar issue. Runs fine as separate scripts, but not as one.
