Group Layer Definition Query - Python Script
4224
09-15-2014 07:40 AM
JasonCowell
Hello,
I'm trying to develop a quick tool to perform a definition query on a group layer based on the users input (Field, Value in Field, and Group Layer). I did some searching around and came up with the script that I have below. Originally I set the field, value, and group parameters directly equal to a particular value and the code worked perfectly. But now I want the user to be able to enter the field and value they want to perform the definition query with as well as which group layer to use. Every time I run the tool it says that "field" is undefined which means some how my parameters are not being returned. Is there some syntax that I'm missing or do I have any of the parameters set up incorrectly. I'm just starting to learn python so any help is welcome.
Thanks.
import arcpy
#Variables to form defintion query
def getParameterInfo(self):
    field = arcpy.Parameter(
        displayName="Field",
        name="field",
        datatype="Any Value",
        parameterType="Required",
        direction="Input")
    value = arcpy.Parameter(
        displayName="Value in Field",
        name="value",
        direction="Input")
    group = arcpy.Parameter(
        displayName="Group Layer Name",
        name="group",
        datatype="Group Layer",
        direction="Input")
    params = [field, value, group]
    return params
#concatenate query syntax
queryStr = str(field) + "=" + str(value)
#Specify the MXD project (CURRENT), dataframe (Layers)
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
#Apply defintion query to specified layer group (Test)
for lyr in arcpy.mapping.ListLayers(mxd, group, df)[0]:
    if lyr.supports("DEFINITIONQUERY"):
        lyr.definitionQuery = queryStr
arcpy.RefreshActiveView()
MatthewLewis
Could you use?
field = arcpy.GetParameterAsText(0)
value  = arcpy.GetParameterAsText(1)
group = arcpy.GetParameterAsText(2)
JasonCowell
That did the trick. Thanks.
MatthewLewis
might be worth marking as answered just so it gets filtered off the unanswered list 🙂
