Getting zmin zmax of a raster parameter in a tool validation in ArcGIS Desktop 10.7 toolbox Python script
1857
01-14-2021 04:43 AM
MarcoBelotti
I am developing a python script tool (my first one). The tool has 3 input parameters:
  1. a raster
  2. z min
  3. z max
I am trying to get automatically z min and z max after the user specify the raster using the validation script but I got this error: TypeError: expected a raster or  layer
This is my code (commented lines are other attempts I tried without results):
def updateParameters(self😞
"""Modify the values and properties of parameters before internal
validation is performed.  This method is called whenever a parameter
has been changed."""
if self.params[0].altered:
  if self.params[0].value:
    #rst_ds = self.params[0]
    rst_ds = self.params[0].value
    self.params[1].value = arcpy.Raster(rst_ds).minimum
    #self.params[2].value = arcpy.Raster(rst_ds.replace('\\','/')).maximum
    #arcpy.MakeRasterLayer_management(rst_ds, "rst_lyr")
    #self.params[1].value = arcpy.Raster("rst_lyr").minimum
return
DuncanHornby
MVP Notable Contributor
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - GeoNet, The Esri Community
def updateParameters(self):
Use python for the language... It will make your def happy again
 The parameter type would be "any" and you have to deal with either a raster or a number being added
... sort of retired...
DuncanHornby
