Getting XY from mouse click using python
33594
22
02-03-2012 07:42 AM
MichelleHawks
Hi all,
I would like to create a button that captures the location of the next mouse click and displays it in LAT/LONG. I imagine is would have to open a submenu which would be closed when the user is finished getting location information. Is there any way to do this using python?
TonyAlmeida
MVP Regular Contributor
I have tried to had this as a scipt tool and as an addin but i am not having any look.
Could someone please guide me through to create this xy button please?
Thanks!
TonyAlmeida
Thank you for the replay but when i replace my exsiting code with what you provided my tool icon indicates it's missing.
Any ideas?
import arcpy
import pythonaddins
class XYTool(object):
    """Implementation for xy_addin.XYTool (Tool)"""
   def __init__(self):
        self.enabled = True
        self.cursor=3
    def onMouseDownMap(self, x, y, button, shift):
        mxd=arcpy.mapping.MapDocument("current")
        df = arcpy.mapping.ListDataFrames(mxd)[0]
        pt=arcpy.PointGeometry(arcpy.Point(x,y))
        #ptfeat=arcpy.management.CopyFeatures(pt,r"in_memory\pt")
        print x,y
TonyAlmeida
I got it to work kind of, i had a syntax error problem. I have fixed it and added the tool button but when i click the button and click on the map nothing happens, nothing is displayed... i am i missing something?
Thanks!
JakeSkinner
Esri Esteemed Contributor
The coordinates will be printed to your Python window.  Open that window before executing the tool.
TonyAlmeida
I found that out just before i saw your post. Thanks!
Is there a way to popup a message with out having to turn on the python window?
DeanCarstens
Hi Tony,
You can do this using the MessageBox in the pythonaddins module.  Pass the coordinates to the message property as text.
TonyAlmeida
I got to pop up the message box, but it has NaN Nan at the end.. what is that?
Would there be a possible way to add the "Long" & "Lat" text to the beginning or the end of the coordinates?
to display like this,
Latitude = 43.5373, Longitude = -114.2578
or
Lat = 43.5373, Long = -114.2578
JakeSkinner
You will just need to add pythonaddins.Messagebox to the end of your code.  Ex:
import arcpy
import pythonaddins
   def __init__(self):
        self.enabled = True
        self.cursor=3
        print x,y
        pythonaddins.MessageBox(str(x) + ", " + str(y), 'Coordinates', 0)
TonyAlmeida
my current code;
import arcpy
import pythonaddins
class XY(object):
    """Implementation for xy_addin.tool (Tool)"""
    def __init__(self):
        self.enabled = True
        self.cursor=3
        print x,y
        pythonaddins.MessageBox (arcpy.Point(x,y) ,'Location','0')
        pass
TonyAlmeida
Thank you JSkinns3!
I was able to figure it out.
import arcpy
import pythonaddins
class XY(object):
    def __init__(self):
        self.enabled = True
        self.cursor=3
        print x,y
        pythonaddins.MessageBox("Long" + " " + str(x) + '\n'+ "Lat"+ " " + str(y), 'Coordinates', 0)
