Getting the Latitude of Origin for a spatial reference
7332
10
06-05-2013 01:12 PM
timloesch
Greetings,
I'm using Python to extract the parameters of projected coordinate systems but I'm finding that the SpatialReference object does not have a .latitudeOfOrigin property that I need to extract.
When I look at the projection parameters in ArcMap the latitude of origin is there but I cannot find where to access that value in the SpatialReference object. I can get all of the other parameters but this seems to be missing.
Can someone point me in the right direction?
thanks
tim
ShaunWalbridge
As of ArcGIS 10.3, this issue is fixed and you can directly use the latitudeOfOrigin property:
>>> sr = arcpy.SpatialReference("NAD 1983 Contiguous USA Albers")
>>> sr.latitudeOfOrigin
23.0
I'd use that over the solution I'd originally posted above for any newer release.
