getting runtime error using arcpy
8173
18
09-18-2017 01:58 PM
DanMacDonald
Hi all
I am trying to write a arcpy script that will turn off all NULL and empty fields. The script runs for a while and then gives a run time error at fields.append(row.getValue(f)). Below is the script.
import arcpy
from arcpy import env
arcpy.env.overwriteOutput = True
arcpy.env.addOutputsToMap = False
arcpy.env.workspace = "C:/temp"
out_layer = "temp.lyr"
mxd = arcpy.mapping.MapDocument('CURRENT')
df = arcpy.mapping.ListDataFrames(mxd, '*')[0] # need to find way to get list of layers there can be more than one data frame
listfields = []
thebadlist = []
for LayerNeedsFieldsTurnedOff in arcpy.mapping.ListLayers(mxd):
if LayerNeedsFieldsTurnedOff.isGroupLayer:
print "group print"
elif LayerNeedsFieldsTurnedOff.isFeatureLayer:
fields = dict((f.name, []) for f in arcpy.ListFields(LayerNeedsFieldsTurnedOff) if not f.required)
rows = arcpy.SearchCursor(LayerNeedsFieldsTurnedOff,"","","","")
for row in rows:
for f in fields.keys():
fields.append(row.getValue(f)) #**the error happens here**
#print row.getValue(f)
for field, values in fields.iteritems():
#print field
if field == "Shape":
listfields.append(field)
elif all(map(lambda s: s is None or not str(s).strip(), values)):
thebadlist.append(field)
else:
# LayerNeedsFieldsTurnedOff = arcpy.mapping.ListLayers(mxd, 'exampledata', df)[0]
# fill in your desired fields to remain visible
desiredFields = listfields
field_info = arcpy.Describe(LayerNeedsFieldsTurnedOff).fieldInfo # I need this for field count
for i in range(field_info.count):
if field_info.getfieldname(i) not in desiredFields:
if field_info.getfieldname(i) == "SHAPE":
field_info.setvisible(i, 'VISIBLE')
elif field_info.getfieldname(i) == "Shape":
else:
field_info.setvisible(i, 'HIDDEN')
arcpy.SaveToLayerFile_management(LayerNeedsFieldsTurnedOff, out_layer)
arcpy.MakeFeatureLayer_management(LayerNeedsFieldsTurnedOff, 'temp_layer', '', '', field_info)
refLyr = arcpy.mapping.Layer('temp_layer')
# rename the ref layer the same as your target layer
refLyr.name = LayerNeedsFieldsTurnedOff.name
lyrfile = "C:/temp/temp.lyr"
print LayerNeedsFieldsTurnedOff.name
arcpy.ApplySymbologyFromLayer_management(refLyr, lyrfile)
arcpy.mapping.UpdateLayer(df, LayerNeedsFieldsTurnedOff, refLyr, False)
# mxd.save()
print 'cleaning up-'
if arcpy.Exists('temp_layer'):
print '\'temp_layer\' still in memory...deleting now...'
arcpy.Delete_management('temp_layer')
print 'deleting obj refs...'
del LayerNeedsFieldsTurnedOff, refLyr, fields
print 'done.'
RandyBurton
Since the code is not properly indented, it is difficult to offer a suggestion.  Formatting your code when posting to Geonet will help: Code Formatting... the basics++
Also, can you include the error message text?
DanPatterson_Retired
Dan could you format the code so that it is readable and syntax can be checked...
https://community.esri.com/blogs/dan_patterson/2016/08/14/script-formatting
DanMacDonald
script code
DarrenWiens2
What exactly is the error message?
DanMacDonald
Runtime error
File "<string>", line 19, in <module>
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\arcobjects\arcobjects.py", line 1100, in getValue
return convertArcObjectToPythonObject(self._arc_object.GetValue(*gp_fixargs(args)))
RuntimeError: ERROR 999999: Error executing function.
guessing on the line numbers, but the line
fields = dict....
can you print the results after that line, because if it returns None, then the search cursor will fail
DanMacDonald
It is down lower in the script  the following
RandyBurton
Looks like the line Dan Patterson‌ is referring to is after the first "elif". Formatting the code for Geonet will provide line numbers and help the discussion.
print statements would still help
