Getting error when trying to Create Buffer using Analysis Services
1825
12-28-2021 01:15 PM
ChuckBenton
I'm trying to create a buffer of all parcels with 100 Meters of the National Interstate systems. I'm using a national feature layer of parcels, and selecting based on the Living Atlas USA Freeway System feature layer. I'm following the workflow at https://developers.arcgis.com/rest/analysis/api-reference/find-existing-locations.htm. The key code is:
host_url = "https://www.arcgis.com"
portal_url = "{}/sharing/rest".format(host_url)
token = get_token(portal_url, username, password)
analysis_url = get_analysis_url(portal_url, token)
task = "CreateBuffers"
output_service = "CreateBuffers_I95"
params= { "inputLayer": {"url": "https://services8.arcgis.com/2G8bTpCps4vdRut5/arcgis/rest/services/ParcelAtlas_V2_4/FeatureServer/0"},
"method": "Geodesic",
"spatialRel": "withinDistance",
"selectingLayer": "https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/USA_Freeway_System_analysis/Featur...",
"distance": 100.0,
"units": "Meters",
"dissolveType": "Dissolve",
"outputName": {"serviceProperties": {"name": "LocationQueryResult"}
task_url, job_info = analysis_job(analysis_url, task, token, params)
job_info = analysis_job_status(task_url, job_info, token)
job_values = analysis_job_results(task_url, job_info, token)
When I run it I get :
importing
starting
Logging in
Getting token...
Getting Analysis URL...
Submitting analysis job...
{'jobId': 'jaf04b394ba164b9d8de5098228b2d6c3', 'jobStatus': 'esriJobSubmitted', 'results': {}, 'inputs': {}, 'messages': []}
{'jobId': 'jaf04b394ba164b9d8de5098228b2d6c3', 'jobStatus': 'esriJobFailed', 'results': {}, 'inputs': {}, 'messages': [{'type': 'esriJobMessageTypeError', 'description': '{"messageCode": "AO_100012", "message": "CreateBuffers failed."}'}, {'type': 'esriJobMessageTypeError', 'description': 'Failed to execute (CreateBuffers).'}, {'type': 'esriJobMessageTypeError', 'description': 'Failed.'}]}
Exception                                 Traceback (most recent call last)
<ipython-input-34-708507b739fa> in <module>
    175         }
    176 task_url, job_info = analysis_job(analysis_url, task, token, params)
--> 177 job_info = analysis_job_status(task_url, job_info, token)
    178 job_values = analysis_job_results(task_url, job_info, token)
    179
<ipython-input-34-708507b739fa> in analysis_job_status(task_url, job_info, token)
    112                 print(job_response)
    113                 if job_response.get("jobStatus") == "esriJobFailed":
--> 114                     raise Exception("Job failed.")
    115                 elif job_response.get("jobStatus") == "esriJobCancelled":
    116                     raise Exception("Job cancelled.")
Exception: Job failed.
There's very little here to go on for troubleshooting, any ideas to try and overcome this are most welcome!
Thanks in advance or any replies and insights!
Chuck
MichaelVolz
Esteemed Contributor
Can you try setting this up in ModelBuilder and then export to python after successful ran and compare to your code?
