GetParameterAsText  "ERROR 000735: Input Features: Value is required"
5996
6
11-29-2011 08:18 PM
darylejohnson
I cannot get this code to work. It is a simple homework assignment- I saw a similar post that I quote below but my problem is slightly different as I wrote the code as script not exported from a model :
I am trying to use the GetParameterAsText to ask the user to give input (to let them choose which featureclass they want to use) from the script. I keep getting the message : "Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000735: Input Features: Value is required"
I cannot get the box to come up asking the user to choose which featureclass to run the script/model on or the output file etc.
Previous poster added the script as a tool and made parameters there but I need to code them from script for this homework- the script works if I hardcode the inputs.
    CODE:
# Purpose: Copy selected features from one feature class into
#          a brand new feature class.
# Import the arcpy module
import arcpy, os.path
# Input feature class.
inFC = arcpy.GetParameterAsText(0)
# Output feature class.
outFC = arcpy.GetParameterAsText(1)
# SQL statement to filter features. If the expression is empty,
# all features will be copied into the new feature class.
expression = arcpy.GetParameterAsText(2)
# Field information to alter output fields. If the fieldInfo
# is empty, all fields will be unaltered in the new feature class.
fieldInfo = arcpy.GetParameterAsText(3)
# Make a temporary layer to hold the selected features and altered fields.
# The selected features are determined by the expression variable.
# The altered fields are determined by the fieldInfo variable.
arcpy.MakeFeatureLayer_management(inFC, os.path.basename(outFC), expression,
                               os.path.dirname(outFC), fieldInfo)
# Copy selected features and altered fields to the output feature class.
arcpy.CopyFeatures_management(os.path.basename(outFC), outFC)
darylejohnson
PS- This script works fine from the windows command prompt like so :
C:\Python26\ArcGIS10.0>python c:\usr\myname\lab12\test\fc2fc.py c:\usr\myname\la
b10\world\world\rivers.shp c:\usr\myname\lab12\test\rivers.shp "" ""
MathewCoyle
Honored Contributor
You have to add your script as a script tool if you want any kind of interactivity with user input, outside of command line parameters as you have already seen. If you do not add your script as a script tool, nothing will pop up asking you to choose anything, unless you design your own GUI to do so.
RuthEmerick
You should also check out sys.argv for user input.
darylejohnson
Thanks guys - but are you sure about that ? I have a video demo of my teaching assistant writing that code manually and running it from pythonwin and an input box pops up- I am brand new to python and arcgis so not disputing you guys but I see it happening so just wondering. Here are our homework instructions directing us to do it that way also :
Step 2: Replace Hard Coded Values With Dynamic Values
Replace the hard-coded values with the arcpy.GetParameterAsText() function.
�?� Save the FC2FC_HardCoded.py script to C:\usr\yourname\lab12\FC2FC.py.
�?� Modify the following variables to accept user-specified input.
�?� Save the script.
He does this manually in the video and immediately runs the script- I will see if I can post a screen shot
MathewCoyle
Honored Contributor
There is no way to code a pop up window without import a gui module like tkinter. He may be using a simple run with parameters button, which is just an option in most moderately advanced python IDEs, and has nothing to do with your code.
RuthEmerick
PythonWin does have a popup for user input for input and raw_input--I haven't used the arcpy GetParameter functions with PythonWin, but I have used the other with it. You could try this:
inFC = raw_input("Please enter parameter 0: ")
outFC = raw_input("Please enter parameter 1: ")
expression = raw_input("Please enter parameter 3: ")
fieldInfo = raw_input("Please enter parameter 4: ")
