GetCountManagement for Mosaic Dataset
1893
02-24-2022 11:43 AM
KeonMonroe
I'm trying to develop a geoprocessing tool for handling mosaic datasets. Using ArcGIS Pro - I can query a mosaic dataset and find how many primary rasters it contains. How can I replicate this behavior in a script? If I had a normal feature class I would make it a feature layer, select on the layer, then GetCount() to find the number of rows.
How would you do this with a mosaic dataset that contains primary and overview rasters?
def query_primary_rasters(input_md):
    """ Return the number of primary rasters in a given Mosaic dataset
    arcpy.AddMessage(f"Input Mosaic Dataset:\n{input_md}")
    query_by = "Category = 1"  # primary rasters
    md_lyr = "md_lyr"
    # arcpy.MakeFeatureLayer_management(in_features=os.path.join(input_md, "Footprint"), out_layer = md_lyr, where_clause= query_by)
    # arcpy.MakeMosaicLayer_management(input_md, out_mosaic_layer= md_lyr, where_clause= query_by)
    # NOTE - below works but doesn't return selected row count (includes all items)
    arcpy.management.SelectLayerByAttribute(input_md, "NEW_SELECTION", query_by, None)
    count_primary = int(arcpy.GetCount_management(md_lyr)[0])
    arcpy.AddMessage(f"There are {count_primary} primary rasters in the mosaic dataset")
    return count_primary
update_md = arcpy.GetParameterAsText(0)
query_primary_rasters(update_md)
RhettZufelt
MVP Notable Contributor
It appears as if Pro's Table to Table tool will allow the mosaic as input, and let you put a query of "Category = 1".  This will output just the primary's to a new table (could probably go to memory, didn't test) that can now be fed into the GetCount tool.
R_
RhettZufelt
R_
KeonMonroe
Thanks, works nicely.
