GetCellValue error: invalid literal for float()
10237
6
01-16-2016 02:26 PM
by Anonymous User
Not applicable
I'm trying to Get Raster Cell Value iterating a row selection over a point feature class and passing the coordinates as a string like this "1590388,53 4881616,56". But i receive this error:
  File "C:\Users\ivn\Desktop\sir\getcellval.py", line 7, in <module>
    Val = float(CellVal.getOutput(0))
ValueError: invalid literal for float(): 3,5872333
This is the script:
import arcpy
rs = arcpy.GetParameterAsText(0) #Input Raster
X_Y = arcpy.GetParameterAsText(1) #Coordinates of point
CellVal = arcpy.GetCellValue_management(rs, X_Y, "1")
DanPatterson_Retired
Get Cell Value—Help | ArcGIS for Desktop
shows using int and it appears it is using local formatting.  have you had issues with the internationalization of decimal formating in the past with the spatial analyst functions.
import arcpy
result = arcpy.GetCellValue_management("C:/data/rgb.img", "480785 3807335", "2;3")
cellSize = int(result.getOutput(0))
print(cellSize)
by Anonymous User
Not applicable
I receive this error for  int:
>>> Val = int(CellVal.getOutput(0))
Runtime error
  File "<string>", line 1, in <module>
ValueError: invalid literal for int() with base 10: '3,5872333'
did you just try printing it out, before doing any conversion?  It would be nice to see if it is even convertable to an integer or a string.  for example, you can search for ValueError invalid literal for int() as an error message.  There are lots of possiblities depending on what your print statement returns.
For example arcgis desktop - What does ValueError: invalid literal for int() with base 10 indicate? - Geographic...
NeilAyres
Are you sure that the point XY as typed in, is within the extent of the raster?
XanderBakker
Esri Esteemed Contributor
This sounds like a case of regional settings. Your result (as a string) contains a comma as decimal (regional settings), but Python will need a point to be able to convert it to float.
Try this:
Val = float(CellVal.getOutput(0).replace(',','.'))
22.2. locale — Internationalization services — Python 2.7.11 documentation
It is possible to internationalize if more than a quick substitution is needed for the decimal delimiter.  The web is aghast with examples .... most use the old replace approach unless you have to do this all the time
