Get User Privileges
10202
11
05-29-2015 08:41 AM
CliveSwan
I am trying to:
1) Determine which tables to select to get the User Privileges
2) Run an arcpy script to get all FeatureClass, Table priviliges
I get an ORA-00936 error (933 ORA-00933: SQL command not properly ended)
The SQL statement is:
sql_statement =
"SELECT OWNER,OBJECT_TYPE,OBJECT_NAME  \
    FROM DBA*  \
    WHERE OWNER = 'GISADMIN' and OBJECT_TYPE = 'TABLE'"
The SQL appears to be correct???
Don't understand why it is returning this error??
Clive
BillDaigle
I agree with Blake about the triple quoted strings.  They are much cleaner and will allow you to copy and paste from a SQL editor like PLSQL or SQL Developer.
sql_statement =  """
                   SELECT *
                   FROM USER_TAB_PRIVS
                   WHERE OWNER LIKE 'GISADMN'
BlakeTerhune
When you have WHERE OWNER LIKE 'GISADMN' without a % wildcard, you're essentially just saying equals. For the sake of clarity, you should change it to WHERE OWNER = 'GISADMN' unless you really do want a wildcard at the beginning or end.
