Get the maximum hight of a 3D line?
1320
03-08-2021 03:03 AM
JohannesBierer
I would like to get the maximum hight of a line feature but it doesn't work with FeatureClassToNumPyArray?
I tried the following code:
def Sperren_interpShape(self):
        arcpy.CheckOutExtension("3D")
        desc = arcpy.Describe(inSperren)
        outFC = "{0}_3D".format(desc.basename)
        method = "BILINEAR"
        # Execute InterpolateShape
        arcpy.ddd.InterpolateShape(inHights, inSperren, outFC,
                                   "", "", method, True)
        arcpy.CheckInExtension("3D")
        arcpy.MakeFeatureLayer_management(outFC, outLyr)
        with arcpy.da.SearchCursor(outLyr, "OBJECTID") as cursor:
            for row in cursor:
                print row[0]
                sel = "{} = {}".format("OBJECTID", row[0])
                print sel
                arcpy.SelectLayerByAttribute_management(outLyr, "NEW_SELECTION", sel)
                arr = arcpy.da.FeatureClassToNumPyArray(outLyr, ["OBJECTID", 'SHAPE@Z'])
                print arr
                print np.amax(arr.astype(np.float))
but it only results in the following print statements:
OBJECTID = 1
[(1, nan)]
1.0
What does "nan" means? Are there better ways to get the maximum hight of a 3D line?
Working in 10.6.1?
DanPatterson
nan .... Not a Number
FeatureClassToNumPyArray—ArcGIS Pro | Documentation
SHAPE@M and SHAPE@Z tokens will only return values if the in_table contains point features and is m-aware (or z-aware). If the in_table contains polygon, polyline, or multipart features, SHAPE@M and SHAPE@Z will return a nan. Any feature class that is not m-aware or z-aware will not support SHAPE@M and SHAPE@Z tokens.
Convert polyline or polygon features to a point featureclass first
then use explode_to_points=True
FeatureClassToNumPyArray (in_table, field_names, {where_clause}, {spatial_reference}, {explode_to_points}, {skip_nulls}, {null_value})
... sort of retired...
DanPatterson
