Get the elevation in an ASCII raster DEM format using python
2261
06-30-2022 02:22 AM
Titiiii
Hi guys !
I have some problems to get the elevation, based on the latitude and longitude of one point, from an ASCII DEM file.
The .asc file looks like this :
ncols 1000
nrows 1000
xllcorner 1213999.500000000000
yllcorner 6153000.500000000000
cellsize 1.000000000000
NODATA_value -99999.00
486.41 486.57 486.47 486.27 486.17 485.98 485.74 485.66
485.57 485.51 485.43 485.34 485.18 485.06 485.07 485.05
484.85 484.84 485.04 485.37 485.73 485.98 486.15 486.51
486.85 487.12 487.53 487.93 488.19 488.56 488.89 489.23
489.65 490.02 490.37 490.72 491.05 491.31 491.69 492.07
492.41 492.82 493.31 493.76 494.10 494.51 494.90 495.27
495.45 495.83 496.35 496.72 497.06 497.17 497.26 497.42
497.68 497.92 498.04 498.15 498.32 498.56 498.77 499.02
First I import the file in a numpy array, having 1000 rows and 1000 columns.
Based on the latitude and longitude of one point I calculate the index on x and y to find the altitude in the  numpy array.
The code to do this is as follow :
#! usr/bin/env python3
#! -*- coding : utf-8 -*-
import numpy as np
Tile = 'T5821_1213999.5_6153000.5.asc'
rep = 'PathToFile' + Tile
par = open(rep)
dat = np.loadtxt(par, skiprows=6)
nc, nr = 1000, 1000
CellsizeX, CellsizeY = 1, 1
Ref_x = 1213999.5
Ref_y = 6153000.5
Max_x = 1213999.5 + nc*CellsizeX
Max_y = 6153000.5 + nr*CellsizeY
def Get_Altitude(dat, nr, GPS_x, GPS_y, Ref_x, Ref_y, CellsizeX, CellsizeY, index_x=None, index_y=None):
    if ((index_x==None) and (index_y==None)):
        # Get the distance between tile reference and point
        dx = np.abs(GPS_x - Ref_x)
        dy = np.abs(GPS_y - Ref_y)
        # Get the index of the current point
        index_x = int(np.round((dx/CellsizeX),0))
        index_y = int(np.round((dy/CellsizeY),0))
        # Get the altitude in the DEM
        alt = dat[np.abs(-nr+index_y)][index_x]
    else:
    if ((alt == -99999.00) or (alt == -9999)):
        alt = 0
    return alt
lt = Get_Altitude(dat, nr, Max_x, Max_y, Ref_x, Ref_y, CellsizeX, CellsizeY, index_x=None, index_y=None)
print(lt)
But when I want to get the altitude of the reference of the tile (bottom left corner), or the maximum (top right corner), I have an error saying that the index is out of the array :
IndexError: index 1000 is out of bounds for axis 0 with size 1000
The index of my numpy array goes from to 0 to 999, so 1000 columns (and rows).
I do not understand why the index calculated for the reference or the maximum is 1000... It should be 999.
Does anybody have an idea about how to fix this problem ? Thanks 🙂
JohannesLindner
When you use Max_X as GPS_X input, dx will be equal to nc*CellsizeX, which would be 1000. index_x = dx/CellsizeX will still be 1000. See lines 16, 22, and 25 in your code, analogous for dy.
The root of the problem are lines 16 and 17. Here, you're telling Python that your raster has 1001 rows/columns: the start row + 1000 rows after that.
This should fix it:
Max_x = Ref_X + (nc - 1) * CellsizeX
Have a great day!
Johannes
