Get Relationship Classes from Table (Not Workspace)
1694
11-21-2013 11:09 AM
brettangel
Any ideas on how to do this? Originally, I thought I could use the relationshipClassNames from the GDB Table properties, but I only get empty value back (i.e. []). Anybody know why this does not work or what I'm doing incorrectly? Not much to this and the example is pulled straight from ESRI help documents.
desc = arcpy.Describe("myTable") print desc.relationshipClassNames
I found this thread with this code
import arcpy from arcpy import env workspace = env.workspace = r'your_workspace' def detectRelationship():      rc_list = [c.name for c in arcpy.Describe(workspace).children if c.datatype == "RelationshipClass"]      for rc in rc_list:          rc_path = workspace + "\\" + rc          des_rc = arcpy.Describe(rc_path)          origin = des_rc.originClassNames          destination = des_rc.destinationClassNames          print "Relationship Class: %s \n Origin: %s \n Desintation: %s" %(rc, origin, destination)          detectRelationship()
, but I don't need to search the entire DB for all relationships. Only a specific table. I could use this code to ID the table and relationships I want, but would prefer to use the relationshipClassNames from GDB Table to reduce the amount of code.
Any help would be much appreciated.  Forgot to add I'm using 10.1.
XanderBakker
Esri Esteemed Contributor
Hi Brett,
If you run the code in the Python window it will work. If you use a standalone script, it won't :(. To solve this you should make a Featurelayer of TableView and describe those objects instead:
Feature class
import arcpy fc = r'\\nlbltfs01\Projecten\307103\werkdir\fgb\BLS_Copy_Paste.gdb\Leiding' arcpy.MakeFeatureLayer_management(fc,"myLayer") desc = arcpy.Describe("myLayer") print "myLayer: {0}".format(desc.relationshipClassNames)
Results in:
myLayer: [u'ZZRC_Leiding_Afsluiter', u'ZZRC_Leiding_Cap', u'ZZRC_Leiding_Diameterovergang', u'ZZRC_Leiding_Flens', u'ZZRC_Leiding_Isolatiekoppeling', u'ZZRC_Leiding_Las', u'ZZRC_Leiding_Leidingzakbaken', u'ZZRC_Leiding_Wanddikteovergang', u'ZZRC_Leiding_TStuk', u'ZZRC_Leiding_Pigmarker', u'ZZRC_Leiding_Ontluchting', u'ZZRC_Leiding_Mangat', u'ZZRC_Persoon_Leiding']
Table
tbl = r'\\nlbltfs01\Projecten\307103\werkdir\fgb\BLS_Copy_Paste.gdb\Persoon' arcpy.MakeTableView_management(tbl,"myTable") desc = arcpy.Describe("myTable") print "myTable: {0}".format(desc.relationshipClassNames)
Results in:
myTable: [u'ZZRC_Persoon_Leiding', u'ZZRC_Eigenaar_Duiker', u'ZZRC_Eigenaar_KruisendeWeg', u'ZZRC_Inspectieweg_Eigenaar', u'ZZRC_Inspectieweg_Onderhoud', u'ZZRC_KruisendeKabel_Persoon', u'ZZRC_KruisendeLeiding_Persoon', u'ZZRC_Onderhoud_Duiker', u'ZZRC_Onderhoud_KruisendeWeg', u'ZZRC_Persoon_Damwandkoker', u'ZZRC_Persoon_Gebouwen', u'ZZRC_Persoon_Gelijkrichter', u'ZZRC_Persoon_Handhole', u'ZZRC_Persoon_KruisendeMantelbuis', u'ZZRC_Persoon_Pachtkavel', u'ZZRC_Persoon_Peilbuis', u'ZZRC_Persoon_Wbe', u'ZZRC_Persoon_Grondzakbaken', u'ZZRC_Persoon_Leidingzakbaken', u'ZZRC_ZakelijkRecht_Persoon']
Kind regards,
Xander
XanderBakker
Hi Brett,
Feature class
Results in:
Table
Results in:
Kind regards,
Xander
brettangel
Xander,
Making a TableView worked perfectly!  Thanks a ton.
brettangel
If you're following this thread any chance you know how to get the primary and foreign keys from a relationship class?
