Get raster cell XY and VALUE?
1761
06-15-2012 07:08 AM
KevinBell
Anyone out there know how to access a raster cell's center XY and VALUE directly?  I could arcpy.RasterToPoint and then get it from there, but that seems like an extra step.
Thanks!:D
BruceNielsen
I don't think you can re-assign a variable while you're using it as an index. You will probably have to break it into 2 lines
for i in xrange(xwidth):     xmin += i     d[xmin, ymax] = ar[0]   for j in xrange(yheight):     ymax -= j     d[xmin, ymax] = ar[0]
Here's what I tried in the interactive window
>>> a=[1,2,3] >>> b=1 >>> a[b+=1] Traceback (  File "<interactive input>", line 1     a[b+=1]         ^ SyntaxError: invalid syntax
KevinBell
Ok, am I going nuts, or is it just Friday?
I'm trying to build a dict of raster values to later build into a point feature class, and I'm getting a syntax error in the += down where I'm filling my dictionary.  I don't see the problem.  :confused:
The dict looks like this:
(x,y): value
I'll append other values to the xy later
import arcpy
import pprint
theRaster = r'C:\gis\solarTESTING\default.gdb\d1'
ras = arcpy.Raster(theRaster)
ar = arcpy.RasterToNumPyArray(theRaster)
xmin = ras.extent.XMin
ymax = ras.extent.YMax
yheight, xwidth = ar.shape
d={}
 d[xmin += i, ymax] = ar[0]
 d[xmin, ymax -= j] = ar[0]
pprint.pprint(d)
BruceNielsen
KevinBell
That did it!  Thanks!  I was going batty!
NOTE that code doesn't do what i want just yet, but it is ok as far as i've gotten on it.
