geometry help w/ da.InsertCursor
9362
16
12-29-2014 10:35 AM
KevinBell
Ok, I'm stumped!  I have a list "xys" that if I do this:
xys.sort()
for i in xys:
    print i
I get this:  (id, xFrom, yFrom, xTo, yTo)
[225351, 1858897, 889223, 1883031, 882436]
[225396, 1908393, 871758, 1908090, 871791]
[225405, 1899127, 884235, 1885213, 861191]
[225423, 1891186, 878961, 1885811, 881262]
[225435, 1887101, 888042, 1894165, 884325]
[225438, 1888139, 885803, 1888050, 885319]
[225438, 1888139, 885803, 1888081, 884837]
[225441, 1885023, 888542, 1884356, 888364]
and then i do this:
for j in xys:
    print j
    myList = []
    myList.append(arcpy.Point(j[1], j[2]))
    myList.append(arcpy.Point(j[3], j[4]))
    array = arcpy.Array(myList)
    polyline = arcpy.Polyline(array)
    cursor = arcpy.da.InsertCursor(output, ("SHAPE@"))
    cursor.insertRow((polyline,))
    print 'inserted row'
I get an empty table...  I had this working at one point.  Any obvious blunders here?
XanderBakker
Esri Esteemed Contributor
interesting, but annoying... If I look at the help of the da.InsertCursor at 10.3:
http://desktop.arcgis.com/en/desktop/latest/analyze/arcpy-data-access/insertcursor-class.htm#C_GUID-...
... I see that they use (as Richard Fairhurst‌ suggests) a list for the fields and insert the row as list. So maybe if you make some minor changes it will work in 10.3 (I can't verify this until next week):
import arcpy
fc = r"C:\Forum\DistLinePol\test.gdb\Polyline2"
xys = [[225351, 1858897, 889223, 1883031, 882436],
      [225396, 1908393, 871758, 1908090, 871791],
      [225405, 1899127, 884235, 1885213, 861191],
      [225423, 1891186, 878961, 1885811, 881262],
      [225435, 1887101, 888042, 1894165, 884325],
      [225438, 1888139, 885803, 1888050, 885319],
      [225438, 1888139, 885803, 1888081, 884837],
      [225441, 1885023, 888542, 1884356, 888364],
      [225351, 1858897, 889223, 1883031, 882436]]
with arcpy.da.InsertCursor(fc, ["SHAPE@"]) as cursor:
    for j in xys:
        array = arcpy.Array()
        array.add(arcpy.Point(j[1], j[2]))
        array.add(arcpy.Point(j[3], j[4]))
        cursor.insertRow([polyline])
DanielSmith
inserts worked for me at 10.3.
refresh in catalog maybe?
are the coordinates posted way out of bounds for the coordinate system?
RichardFairhurst
I agree with Daniel that the code Xander posted (using tuples or lists) works with Python 2.7.8 and ArcMap 10.3.  I get the same results he showed.  The coordinates work even with my default state plane coordinate system which is not really designed for this data.
Sounds like a reboot is in order if it is not working.
KevinBell
Reinstalling now.  My upgrade must have gone wrong.
Thanks everyone!  The application here's pretty cool.  This will be like a live spider diagram showing police officers converging on a call for assistance.
DanielSmith
cool. share a final output when you can .
KevinBell
Ok, my police "calls for service" map is done with lines showing who's assigned to whatever call!  Thanks for your help everyone.  (this refreshes every 30 seconds)
XanderBakker
Cool! Nice Work!
