Function to delete records
10727
11
05-19-2016 10:45 AM
LianaSmith
I need a small code in python that will delete records that have empty value in a specific field of the layer. The name of the feature class is WCSCustomer and the name of the field is GROUTE
curtvprice
I found code to strip all non printables on StackOverflow.
def stripper(s):
    return "".join(i for i in s if ord(i)<127 and ord(i)>32)
fc = r"C:\tmp\Test.gdb\WCSCustomer"
field = "GROUTE"
with arcpy.da.UpdateCursor(fc, field) as rows:
    for row in rows:
        try:
            val = stripper(s)
        except:
            val = row[0]
        if val in ["", None]:
            rows.deleteRow(row)
DanPatterson_Retired
with the unicode encoding cavaet is people move closer to python 3.  Make sure you read that full thread, it is interesting... a "space" is much like "nothing"..it comes in many forms
