from os.path import expanduser
1585
06-17-2014 10:48 AM
JohnLay
I am trying to identify the current user folder as part of a larger process. I am using the code
from os.path import expanduser HOME = expanduser("~")
If I run the script in the foreground the result is:
print HOME 'C:\Users\jlay'
However if I enable background processing the result is
print HOME 'H:\'
Can someone tell me why that is? And how to correct it?
MattEiben
I'm not entirely sure about that behavior, but here's an alternative approach.
# Get your current user name usrName = os.getenv('USERNAME') Home = r'C:\Users\%s' % usrName
Though this will only be useful if your path is constant and you just need to adjust for user name.
MattEiben
JohnLay
That worked. Thanks.
