Format numbers in Field Calc/Python
3768
10-13-2015 09:02 AM
GeorgePapamihalakis
Hi, I am new to python and I am trying to format numbers and concatenate them using python. I basically want to pad numbers with 0s. For example, 5236 should be formatted as 05236 or if it was 300, it should be 00300. I have 4 fields that I want to concatenate.
SSN - no formatting
Block - 5 characters
Lot - 4 characters
Qual - 5 characters
Here is what I have so far, Im not sure why my formatting is not working.
!SSN! + '-' + !BLOCK!.format(00000) + '-' + !LOT!.format(0000) + '-' + !QUAL!.format(00000)
DanPatterson_Retired
A tip
>>> frmt = "{}-{:0>5}-{:0>4}-{:0>5}".format("abcd",123,456,7890)
>>> print(frmt)
abcd-00123-0456-07890
As you see fit...
read the docs  Python mini format language​  applies to python 2.7 and 3.4 etc
Learn more....
https://community.esri.com/blogs/dan_patterson/2015/10/13/before-i-forget-17-formatting-in-action
IanMurray
Honored Contributor
I'm not good with the .format string function, but the .zfill string function should do what you need
from 7.1. string — Common string operations — Python 2.7.10 documentation
https://docs.python.org/2/library/string.html
string.zfill(s, width)
Pad a numeric string s on the left with zero digits until the given width is reached.  Strings starting with a sign are handled correctly.
DarrenWiens2
This is specifically handled by zfill():
>>> block = 5236
... print str(block).zfill(5)
05236
GeorgePapamihalakis
Awesome! Thanks for the quick responses everyone, I used the zfill function.
Thanks!
